HookLine wrote:
I run my 2" neutral column at about 1300-1400 w. Some stillers run harder than that, some slower.
On a spirit run in pot still mode, I judge heat input by condensate output rate. I start at about 2 drops a second for the fores, then 4-5 drops for the heads, and for the hearts I set the rate where it just starts being a solid stable stream, about the thickness of a pencil lead. These different output rate correspond very roughly to maybe 600 w, 800 w, and 1000-1400 w.
The output rate tends to drop over the hearts cut if you hold the power input the same. So I turn the power up a little every so often to keep the output rate the same, and by the end of the hearts it is on about 1300-1400 w.
(P.S. I have a well insulated boiler.)
Being a simple man, I was trying to imagine a simple, 'me proof' way to regulate the power to a hypothetical 20l pot still when I had a hair brained idea, but since I am not an electrician I'd like to be shot down now if I've got this bass-ackwards, before I waste my time and money, kill myself or cause the next Chicago fire.
My idea was I could mount two elements in my boiler:
One 3000w 240vac element running at 120vac for 1/4 the wattage, if I'm remembering correctly, resulting in an improvised 750w element for a 'low' setting that seems to correspond (slightly) to the lower end of your rough wattage to output estimates, -and-
One 1500w 120vac element to be used in conjunction with the 750w element on heat up, and by itself as a 'high' setting towards the end of a run.
Is this foolish, is a hard wired power control like this too coarsely grained? Am I be better off in the long run biting the bullet and building one of pint's controllers which everybody seems to love? My only concern with pint's
controller isn't the design, but my ability to execute it without 'riding the lightning'.
I'd like to apologize ahead of time if I've asked too many dumb questions already answered elsewhere, I searched for similar ideas but maybe I just wasn't searching for the right phrases.
