point of using a 3 way valve is to choose between sending the spent wash to the boiler or to drain it directly. if you were sending it to the drain, then you'd open up the line fron the coolant water to keep the boiler full.Nykter wrote: Whats the function of the three-way valve? I dont think you should mix spent wash with the steam generation system, to avoid reboiling yeast cells. if you do, you could use spent wash only for steam generation, you willsave on energy doing that.
I had actually drawn that up, but felt it made the drawing a little difficult to follow. but it is a good idea.Nykter wrote: Create an overflow exit "waterlock" for the spent wash too, and maybe connect the exits further down to cool the spent wash making it smell less, and being nicer to your plumbing.
Hadn't thought of that, thanks.Nykter wrote: Also be sure to insert the wash into the center of the column, if you follow your drawing it is inserted at the column wall, which might make it follow the wall, reducing column efficiency.
the flow control is a great idea, but I'm shooting for an all gravity feed system, Like I mentioned earlier, I may use a thermostatically controlled valve to regulate the wash input. I'll probably play with the idea on the prototype anyway.
