Need help now!
Need help now!
My ferment is stuck and the wash is only 5 hours old. Did I pitch the yeast to early? I pitched while the wash was still 110 degrees Fahrenheit (!). I did this before and it worked out but I am getting negative returns now! HELP!
Re: Need help now!
What was the recipe? Some times yeast takes a while to get going unless you made a yeast starter it can take 24 hours for the yeast to get going. Leave it for a bit longer and see if it starts.
Re: Need help now!
The recipe is as follows:
5 lbs. white sugar
5 lbs. molasses (cooking quality)
1 lime
1 multivitamin
4 gallons bottled spring water
5 oz Montrachet Dry Wine Yeast
7 oz Fleischmann's baking yeast
I started both yeasts in 105 degree water/mash mix and both took well. I pitched both while the wash was a little over 110 degrees F.
5 lbs. white sugar
1 lime
1 multivitamin
Re: Need help now!
Many times when I put down a wash it will start bubbling straight away and then stop for a while only to restart later. The initial bubbling is usually the oxygen bubbles generating as you make the wash, these eventually die down to be replaces with O2 generated by the fermenting yeast. Like I said in my previous reply leave it for 24 hours and you will probably find it OK.
Re: Need help now!
Thanks for the help! I am on a timeline here!
Re: Need help now!
Shake it up get some oxegen into it.
Re: Need help now!
Product info on dry active allows for a 115 degree pitch but your wash is borderline too hot to keep or install oxygen.
As rubber duck recommends or pitch more.
Re: Need help now!
a time line??? these things take there time and they don't like being hurryed or pushed alongDGiovanni wrote:Thanks for the help! I am on a timeline here!
GOT BAIT?
Re: Need help now!
Sure hope the wash didn't heat up and kill the yeast...
Re: Need help now!
If heat is the problem, its probably cooled down a bit now after 5-6 hours, pitch some more yeast, the dead yeast will be a neutrient for the new yeast.
Re: Need help now!
By walking slower, it will be possible to arrive sooner.
Re: Need help now!
well, it is a slow ferment. my air lock is not bubbling but the wash is fizzing. I added some air (blew bubbles with a tube) and added some cereal to the mix for nutrient. I might just end up being a slow ferment.
Re: Need help now!
Over half a pound of two yeasts sounds interesting and excessive to me. I use a desertspoon or so of bakers yeast for a five gallon wash. Why two yeasts, dgio?
blanik
blanik
Cumudgeon and loving it.
Re: Need help now!
Also one lime might not get the ph down enough.
Re: Need help now!
I meant grams of yeast, not oz! sorry. I might add another lime to the mix. It is going, just not as aggressive as I want it to be. I am adding the juice of one more lime. After that I am not messing with it anymore!
Re: Need help now!
That sounds better.DGiovanni wrote:I meant grams of yeast, not oz! sorry. ...
blanik
