DCT wrote:rumball
here is my chunk of copper, 22" inches long, here is what im thinking, cutting 5" piece for mounting to keg & bottom of ball, leaving the rest coming off top of ball, then figure what angle I want cut top of pipe to angle & match lyne arm, think it should be plenty long with lyne arm at 24", just think less joints to fail from stress?? this pipe od is huge, i will even be able to polish the inside, & is easy to clean as I can fit my entire arm in it..
Super Sankey Scotch Style Still
evilpsych
Re: Super Sankey Scotch Style Still
I just realized that my life is a very complicated drinking game...
DCT
ok, here is where im at, ready to start cutting...think i will make the extra short piece the lyne arm attaches to rather than just cutting the long piece above the ball & attaching lyne arm direct, decisions decisions....wish i would have got a ten inch ball now as the 8 inch looks small on the 6" od pipe...any input???
thanks
thanks
DCT
lyne arm....sorry pics are poor from cell phone, will get better ones later
DCT
hmmm...where to cut?
Just a thought, DCT... Put the ball on top of the column and attach the lyne arm to it... It'll allow you to select your lyne arm angle...
DCT
great idea! problem holes in ball are already cut, should have thought before holes cut....damn it
DCT
width of ball after ends removed, no it would not fit pipe, thought about reataching ball ends but holes were milled on lath & now there would be about 3/8 gap to try t fill, think im stuck with ball on bottom.
DCT
Rad
question, would there be any bennifit to adding copper to the inside of the 6" pipe? like a piece of 1" caped going threw multiple copper bowls with holes drilled in the bottom them...any redistillation to this?? maybe a dumb question?
ANYTHING in the vapor path is going to contribute to at least a small amount of reflux... What that ANYTHING is comes down to is materials on hand, complexity of integration, and personal preference...DCT wrote:Rad
I've actually pondered orbs attached to a rod/tube in similar fashion to your idea of bowls... They would cause the vapor speed to fluctuate, theoretically causing vapor to collapse onto the orbs, running down over them, dripping off onto the the next lower orb, and re-vaporizing... Spacing between orbs is subject to speculation...
still crazy
Were gonna need a bigger boat !!!!!
DCT
Rad
that is what I was thinking, may put a small copper rod near top of column, then make simple copper hooks at the top of reflux piece so it hangs in the tube, then it can be removed for cleaning
DCT
I got 3 ss 15.5 gallon kegs today for $40.00 on craigslist, is this a good price or average or high?
pumpman
40.00 for all three or each? If each you got them for a decent price but if your talking the whole kit&caboodle then you da man.
DCT
all 3 for $40.00, i thought it was a good price but wasnt for sure if people were paying for them or getting them for free...lol
- LWTCS
Hilarious.still crazy wrote:Were gonna need a bigger boat !!!!!
DCT, got enough copper left to build a block head like Hawke's?
http://homedistiller.org/forum/viewtopi ... d#p6805648
Orb on the bottom, blockhead at the top,,,,,oooooooooah more copper envy.
DCT
ok, the still continues...got my cuts done today, try cutting 6" od at angles, luckily my friend had a 15" mider chop saw, man the copper was flying...and yes I did polish the inside
DCT
getting everything preped to solder this week, damn building a simple pot still even takes alot of time, but here is the general design, any suggestions before I solder it all up?
DCT
another view, just hope I dont put to much heat to lyne arm & break the seam lose, will be wrapped with alot of cold wet rags!
Pamulli
DCT, I actually got 2 15.5 gallon kegs for free by contacting some of my local breweries. The one that gave them to me had them stacked up in the back because they rent theirs but sometimes the distributor brings them someone elses which they can't use so they literally just throw them in the back yard.
I got everything built this weekend except installing the heating element and making the controller.
Here are some rough photos.
DCT
VERY NICE!!
Is that all 6" tube? how did you attach to keg? can i get some pics of that? also is that a temp guage? please show a pic of how you attached it. how did you make your flange? great job on the build!
Pamulli
DCT, Mine is primarily 3" tube with a small 4" piece at the bottom to attach to the keg. I welded a new 4" ferrule onto the keg and am attaching with a standard 4" triclamp to 4" copper. I did the weld myself with my mig welder and it turned out OK. Not the prettiest weld I've ever seen, but definitely water tight. I hammered out a flange on my 4" pipe and inserted some copper sheet inside to add a lip to it that gets inserted into the ferrule on the keg which I'm hoping will cause any reflux to drip down into the keg and lessen leaks plus it gets everything lined up when clamping it down. It also gave me a wall so that I could put solder on the top of the flange and get it good and flat. The very first picture I posted shows the flange upside down, but I'll see if I can get some better pictures of that when i get home tonight.
I made the lyne arm out of 3" copper tubing and like Rumbull, I cut out a wedge and then worked it back together with clamps. That part turned out a little rougher than I would have liked. Unfortunately I learned why you anneal copper AFTER doing that piece so there are more dents and dings than I'd like, but we'll just say it gives it character.
And yes that is a thermometer on the top. The thermometer has a 1/4" NPT connection on it so I used a 1/4" female fitting and drilled a hole in my tubing at an angle to make it easy to see and soldered in the female fitting. The thermometer can then just screw right in and if I ever decide I don't need it I can easily plug it or remove the whole fitting. Since I'm new at this I'm OK with using it as a crutch until I can do everything by taste and feel.
I made my column taller than some I've seen on here primarily because most of the traditional Scotch stills I've seen look like they have a really tall column and that is the type of whiskey I'm after. I can always shorten it if I'm getting too much reflux.
To me, building this was easy compared to making a controller for the 240V heating element. I'm still a little lost on that one. I'm hoping I'll get some responses on the Heating Element Control thread to help me figure that one out.
DCT
sounds like we are in the same boat, still looks great, keep on posting!
DCT
here is a removable piece that i will be able to hang in the column for a little reflux if wanted
Pamulli
Sorry I went to a Macallan tasting last night and didn't get to take more pictures. I did however get to sample some really good scotch
Yours is looking great. I like your idea of the optional pieces to add reflux. That is also what I was thinking with cutting the tabs into my onion. I left every other tab sticking out into the vapor path and I can always bend them down out of the way if it has an undesirable affect.
DCT
the giant continues to grow...drinking straight mezcal at the moment....wooohoooo
DCT
here is how i decided to mount to keg, stoped by local bus muffler supply shop, had them cut a chunk of ss & flare the end to fit copper, just slides in, then clamped with ss pressure clamp.
- LWTCS
Looks great DCT.
To bad your stainless couldn't be the male end and the copper be the female.
Should be fine though.
DCT
i tired, but the man running the flare machine would not try it, b/c he said the copper would tear, i dont think it would have, but it was my last piece so i dint risk it.
olddog
He's pulling your chain, copper would have flared easy, even easier if it had been anealled.DCT wrote: the man running the flare machine would not try it, b/c he said the copper would tear
DCT
doing 1st cleaning run with no condenser, may need some help learning to run this beast, took about 45 minutes to boil outside in low 40's...how to bring to a temp of 172 with out boiling to fast, will this hurt the spirit? a therm may be in order?
