redistilling
Shinner73
redistilling
Post by Shinner73 »
When I go to run my collected spirits through the still a second time, do I need to dilute them, or can I pour them in full strength and run it that way?
Tater
Re: redistilling
Post by Tater »
Ya could but most don't for safety reasons.Most seem to prefer to keep around 40 proof or so 2nd time around . Ive reran 80 proof before in metal shed with cement floor but watched it like a hawk with water hose handy .
Dnderhead
Re: redistilling
Post by Dnderhead »
yep I have also, to me the first few minutes are hart pounding.after it is purged not so bad.
blanikdog
Re: redistilling
Post by blanikdog »
Braver men than I am, gunga dins. :)
Stuff that, I'll stick to diluting being a born coward.
blanik
Cumudgeon and loving it.
hstuurman
Re: redistilling
Post by hstuurman »
blanikdog wrote:Braver men than I am, gunga dins. :)
blanik
A living coward instead of a dead runner. Why would you take the risk, and don't dilute?
I always dilute, rather drinking in my chair than drinking on a cloud.
But serious, what advantage is there for not diluting and do a second (or third) run higher than 40??
Henk
Henk
nonereally
Re: redistilling
Post by nonereally »
dilute to 40 proof ? I just want to find out if you meant 40 percent ?
Re: redistilling
nonereally wrote:dilute to 40 proof ? I just want to find out if you meant 40 percent ?
Rather than relying on percentages and/or proof alone, diluting to the point where your low wines won't burn is the safest bet... The initial boiler charge will have the highest concentration of alcohol and if it won't burn then, it never will... Now, should you have a catastrophic failure, you will only need to worry about the explosive vapor the still has produced and not flammable low wines because they have been rendered non-flammable... I always dilute to the point where the low wines won't burn, even using electric...
olddog
Re: redistilling
Post by olddog »
40%ABV which is approximately 80% proof.
OD
Tater
Re: redistilling
Post by Tater »
blanik
Henk
When ya need real high proof with a pot still for making liqueurs
hstuurman
Re: redistilling
Post by hstuurman »
tater wrote:When ya need real high proof with a pot still for making liqueurs
I always dilute to 40%, triple distill sugarwash. After de third run, in my potstill, I've got 85 % clean alcohol. Smooth for making jenever, is good enough for liquors.
So I still don't understand the need of taking the risk. With diluting you can still get a high percentage. A wine lower then 40% (checked with an alcoholmeter) is save to use.
Henk
Henk
