Mentors,
I am building an all copper round pot still 15 inches wide by 18 inches tall. I normally distill outdoors but that is not an option at this point so I am thinking of using a 1500 watt hot plate to provide the heat for this still. My question is if the hot plate will provide enough heat or should I persue a different option. My calculations have the volume at about 15 gallons.
Thanks for your help folks. I love this site.
raildog
hot plate to distill with
Re: hot plate to distill with
15 gallon boiler or 15 gallon charge?
Does your hot plate cycle?
sorry i wasn't clear, 10 gal. charge, 15 gal capacity. Thanks
1500w is a bit low for a pot still that size. The hot plates work fine for a smaller boiler on a reflux still, but for a pot like that you would be better off with immersion elements. IMO, but I have just fitted two 3kw elements to my keg - so I would say that. ![Laughing :lol:](./images/smilies/icon_lol.gif)
Internal elements have a greater thermal efficiency than hot plates... If you can do internal, by all means, do so...
The fact that the pot will be copper means that you should get reasonably efficient heat transfer. A 1500W hotplate is definitely not your best option for heating, but if you have to use it, the copper pot will absorb the heat a lot more efficiently than a stainless pot of the same size and might just do the job. But I suspect your start up times are going to be pretty slow.
Give it a try if you've got the hotplate already, its not as if it'll cost you any extra and wont take any modifying of the pot, but I suggest you'll end up following RAD & Myles advice and going internal eventually.
Well guys I went back to using propane, I hate getting all that soot on that pretty copper buy what the heck. I will just have to find a more descreet place to practice this craft. I had been running 2-15 gal batches of UJSM but thats producing too much so I cut it back to 1-15 gal at a time.
Did I mention I love this site? Thanks for all the help and advise oldtimers.....lol, I ment that in the best possible way guys.
Raildog
Raildog
You could try using a grate of some kind between the copper pot and the burner. That or a diffuser plate of somekind...might stop the discoloring as well as help spread heat more evenly.
thanks, i'll do that
