That's it for everything else but the caps.Kentucky shinner wrote:how would it be if I used acetylene torch and used hard silver solder?
We solder them soft to get 'em off easily if ever needed.
Yes Larry, I use copper caps. it's the only copper part in all my still.LWTCS wrote:Joe are you using copper caps?
I thought I remembered you had these fabricated already?
You didn't think we were just a bunch of toothless podunks making rotgut with a rusty re-purposed oil drum did you...??? This is where all of the new ideas come from, not from modern day distilleries where experimentation is frowned upon due to legal constraints... Not that everything we do around here is new... Improved might be a better word, perhaps...rockchucker22 wrote:Wow wow and wow, I just read through this whole thread and I am impressed to say the least!
Yes Larry, you missunderstood.LWTCS wrote:Say that again Joe.
Single floating bubble cap is proven for a while now.
Or did I misunderstand you.
With some creative brickwork, and a near watertight door, you could disguise it as an outdoor oven...maybe even make a functional outdoor oven and still combo...oh dear..the wheels are turning.rednose wrote:Yeah, all numbers in Cm.
Would make a nice addition to your pool area with a brick insulation.
When you don't use it you can tarn it as a solar powered water fountain or just put a pot with flowers on top.
I am looking forward to see this one Joe, are you going to post some pics?rednose wrote:I will go for a 9 plated bubble column in 8 inch.The column and bubble plates will be copper, the shotgun dephlagmator and condenser in SS.
Sure I will, but it might take some time to start with as I already mentioned.olddog wrote:I am looking forward to see this one Joe, are you going to post some pics?
OD
Excellent! So how does it feel to be a legal beagle?rednose wrote:I’m officially licensed now, hurray.![]()
Joe
