Yup , I been makin quite a bit of apple pie from this here sweetfeed whiskey. Makes fer a tasty drink after a couple weeks mellowin. That is I let the Apple Pie set for a couple weeks after I make it up before drinkin. Smooths out nicely.corncooker69 wrote:Anybody else using this in blends.
I have been double stillin this wash and cutting to 70% abv and then I take half of a pint of that and add my apple pie mix that I make from some Apple cider , brown sugar and cinnamon sticks.
sweetfeed whisky
Re: sweetfeed whisky
This is grain, which any fool can eat, but for which God intended a more divine means of consumption...
apple pie is one of my favorites... mmmmm ammmm mgooooodddd
Ok, im hooked. Where do I find the recipe for the Apple Pie. I have heard so much about this at my events I NEED to make some... Where do i get the recipe??????
Spooky, you been nippin' again...???Mr.Spooky wrote:wait,,, did i miss something????? what size is your ferment?LHD wrote:I just threw together a 12 gal batch yesterday.
Horsemens edge 12% sweet
4 lbs brown sugar (all i had)
10 lbs white sugar
2 packs whiskey yeast w/ag
Maybe I should have taken it easy on the sugar because of the enzymes but, I'll see what happens.
It took off pretty darn fast and strong. Smells great.
spooky
http://www.sirius-speedway.com/2007/12/ ... shine.html" onclick="window.open(this.href);return false;" rel="nofollowcannonman wrote:Ok, im hooked. Where do I find the recipe for the Apple Pie. I have heard so much about this at my events I NEED to make some... Where do i get the recipe??????
you could also use the HD Google Search feature at top of page and punch in appropriate search data.
cheers
stilly
so when wee distill the wash, do we do a fast pot still run , and the second run also fast , with cuts ?
mine is close to finish after 10 days.
oooopss missed thatrad14701 wrote:Spooky, you been nippin' again...???Mr.Spooky wrote:wait,,, did i miss something????? what size is your ferment?LHD wrote:I just threw together a 12 gal batch yesterday.
10 lbs white sugar
spooky
i think is just doin selective readin
spooky
LOL!!! Been there, done that. Had out beloved Mentors rake me over the coals. Well I did turn red from embarrasment.
ArkyJ
ArkyJ
When I was running my pot I did fast stripping runs then did my spirit run making strict cuts...flip wrote:so when wee distill the wash, do we do a fast pot still run , and the second run also fast , with cuts ?
I have done a first run as a reflux run..both come out pretty nice. The reflux will have a little smoother taste.. That is my opinion.
KS
i ran mine a little different.. i would do a slow first run, collecting everything from 80% down to about 60% (i think that this was sugested in the UJSSM recipt as "generic cuts") . on a 12 gal run, this wouldent yield alot, but you did get enough to keep ya until the next run. i find this "generic cuts" to benifit me, because it dident allow me to get too greedy, AKA, dippin into tails.flip wrote:so when wee distill the wash, do we do a fast pot still run , and the second run also fast , with cuts ?
after doing the generic cuts,, i would then run the piss out of it and put all of that into a spare keg and cap the keg. then just repete the process as many times as it takes until the second keg got about 4 or 5 gals in it.. then dilute, and another slow run.
spooky
it was a 12 gallon batchMr.Spooky wrote:wait,,, did i miss something????? what size is your ferment?LHD wrote:I just threw together a 12 gal batch yesterday.
10 lbs white sugar
spooky
No worries. I'm a selective reader while i'm "tastin" too!
If I'm not mistaken, i thought the generic cuts are from 80 to 70.
you are right, they are... after i did that for a while, i got a little more comfy with it and eased on down a little.LHD wrote:If I'm not mistaken, i thought the generic cuts are from 80 to 70.
iv been doing this for a few years, and im still not ready to get away from the generic range. id suspect for someone to be able to truly freestyle cuts and ABV, theyd have to have some time devoted.
spooky
First ferment of this and it finished in about 60 hours. Perfect day to run it since there's 2 feet of snow outside.
Let us know how it comes out for you..
I didn't see anything during fermentation, but there seems to be a lot of oil on the surface after it was racked into the boiler. has anyone else experienced this?
Hmmm..... Oil on the wash huh? Never heard that one. I would suspect the feed. Did it have pellets? Whats in it? I used to work in a feed mill that used chicken fat as a binding agent in pelleted turkey feed. Not saying thats the case just saying......LHD wrote:I didn't see anything during fermentation, but there seems to be a lot of oil on the surface after it was racked into the boiler. has anyone else experienced this?
just rechecked the label and it said there is soybean oil in it.
I ended up siphoning and leaving the oil behind and it does tase good but just too messy to deal with again. time for a trip back too the feed store.
Bingo. Good luck man.
thanks for replies guys
my wash is ready for the still, now i am not so certain of how the filtering will work, i will just let the wash seep through the grains ,and again till clean.
distilling however ,fast stripping yes ,and then reflux , my reflux produces should not drip but pencil run stream .
This wash sounds delicious and I can't wait to get my still put together and give it a try!
today i ran the pot still fast, and was very happy with the result.
so i rerun it with the pot still kinda fast, the shine came out with much higher percentage ,so i deluded it , and tasted it, its very nice but sharp.
i will age it with barrel wood sticks, taste again later.
Leave you some clear.. I think you will really like it.
i made a small mistake, did not realize that the second run is higher in alcohol content,so i tried to receive same amount as was firstly obtained during first run,
ja i think by doing that, i went too far into tails. never mind it still tasting better than any thing i made before, yes and i will leave it white
i mix just about all drinks with coke. i poured backwash and more sugar to restart the second wash.
Hello all. I am a rookie bootlegger and barely know what I'm doing. I've done some basic fermenting and distilling with sugar, water and distiller's yeast, but that's about it. I've been reading up on this sweetfeed whiskey and would like to try it out. I understand the basic recipe concept: 4" of sweetfeed in a 5 gallon fermenter, add boiling water, add sugar, let it come to temp and add the yeast. Do I need to add any amylase extract to the wash or does the boiling water already acheive that conversion of starches to sugars? Did I miss anything in the aforementioned recipe? How do I reuse my yeast? How do I continue to reuse my wash for more batches? I'm still new to the lingo so I may not know all of the verbage used. I would appreciate any feedback. Thanks!
it is not converting any starch.the molasses,sugar are fermenting with grain for flavor.
if you look many add more molasses/water and sugar to the old grain/yeast bed.
Update: I did run the first batch of sweet feed and it came out preety good... OK. now I made my first SECOND generation of the sweet feed. Boy, after it cooled evough for me to pour it over the other feed, it took off like a trooper. I took out four cups of old feed and inverted the old wash and four lbs. of sugar and four cups of new feed. Let it sit till it cooled enough and poured it over the old feed. In about 30 minutes I saw BUBBLES!!! Wow. Will check it tonight to see how its doing. Today is day three on the new wash. OOOHHH, the hydrometer read 1.052 in the new wash.cannonman wrote:Cool, thanks. I will see how it goes this coming week end if its ready to go.Smokehouse Shiner wrote:No cannonman, if you've kept your yeast bed healthy and happy, that is wet and in a good temp range,you do not need to add more. The yeast thats in the bottom of your fermenter is good to go.....
Tell you more later.
I was tasting the wort from this recipe yesterday while I was racking it off of the corn. Pretty tasty stuff! The corn looked in good shape so I'll leave it in the fermenter in some liquid until I can try my first backset mash. I scaled the recipe up from 6 gallons to a 12 gallon fermenter, except I put 8" of cracked corn into it like a total dumbass. The volume of the cracked corn was probably about four times what I should have put in it and once i clued in I just sanitized another 12 gallon fermenter and split the corn. I took it as an opportunity to race baker's yeast against some brewer's yeast. The baker's won by a long shot. I'll be stilling the first batch tomorrow in my detuned column, and the second batch isn't ready yet.
Moved on up from distilling neutrals from simple cereal mashes to experimenting with grains and oaking.
kentucky shiner, why use that much yeast when the other only calls for 1 packet. Im new to distilling. I have my still built but im getting the ingredients together right now. where do I purchase that yeast your using or should i just use some wal-mart yeast.
