gasket help!!
jackson98
gasket help!!
Post by jackson98 »
what type of gasket do yall use to connect a tri-clamp to your keg? I have found some high chemical tolerant ones but i know a lot of people have problems with stuff like that. Any ideas?
banter_king
Re: gasket help!!
Post by banter_king »
a lot of guys make their own "washers" type things out of copper. I personally don't use one just really clamp it down and apply a bit of flour paste with great success.
Knee deep in the cool and soothing waters of ol' Cripple Creek
Braz
Re: gasket help!!
Post by Braz »
I use a PTFE gasket. Like this: http://www.hillbillystills.com/Teflon_G ... /ptfe2.htm" onclick="window.open(this.href);return false;" rel="nofollow
You may need to sand off the ridge from one or both sides depending on your connection.
Braz
yankeeclear
Re: gasket help!!
Post by yankeeclear »
+1 on a modified PTFE
“Half the lies they tell about me aren't true.”
-Yogi Berra
jackson98
Re: gasket help!!
Post by jackson98 »
thanks braz just what i was looking for but i couldn't find them anywhere, got them on order so next run i should be good.
bluethumb
Re: gasket help!!
Post by bluethumb »
Maybe breaking the rules here but I cut out a washer from an old pair of jeans and keep it lubed up with flour/water and it works great for my tri clamp connection.
olddog
Re: gasket help!!
Post by olddog »
A few turns of PTFE (plumbers) tape will do the trick, cheap and replace each time. :mrgreen: :mrgreen: :mrgreen: :mrgreen:
OD
frozenthunderbolt
Re: gasket help!!
Post by frozenthunderbolt »
bluethumb wrote:Maybe breaking the rules here but I cut out a washer from an old pair of jeans and keep it lubed up with flour/water and it works great for my tri clamp connection.
Should be fine. Jeans is just cotton.
Kal
Re: gasket help!!
Post by Kal »
olddog wrote:A few turns of PTFE (plumbers) tape will do the trick, cheap and replace each time. :mrgreen: :mrgreen: :mrgreen: :mrgreen:
OD
This is what I use (wonder who told me this trick :wink: ) and it works a treat!
hackware
Re: gasket help!!
Post by hackware »
just make sure it's woman's jeans... :lol:
tell me how hard it is to do... tell me how expensive it will be... just don't tell me what i can not do...
lead, follow, or get out of the way... ankle biters will be kicked...
•*´¯)¸.•*´¯)¤ª"˜¨¯¯¨˜"william..."˜¨¯¯¨˜"ª¤(¯`*•.¸(¯`*•
beginners _luck0920
Re: gasket help!!
Post by beginners _luck0920 »
Does anyone know if silicone gaskets are acceptable?
frozenthunderbolt
Re: gasket help!!
beginners _luck0920 wrote:Does anyone know if silicone gaskets are acceptable?
My understanding is that some people are (personaly) happy with some kinds but general consensus is against them. Ymmv.
Re: gasket help!!
Don't use any synthetics that you cannot verify through MSDS documentation as being safe with high temperature high proof alcohol vapor and liquid... Hot alcohol is a caustic agent that can melt synthetics or at the very least leach harmful components out into your spirits... Also, simply being claimed to be "food safe" should not be mistaken as a guarantee of the synthetic withstanding the rigors of the distillation of spirits... Our safety motto is "When in doubt, leave it out."...
