New guy from texas
New guy from texas
New guy in tx. Howdy everyone. Been brewing beer for quite some time. Got some friends that have been distilling for a few years. I am building a pot still, 30 qt. 1" column to a 3/4" worm. Ive done a few mashes in 5 gallon buckets. Tried em out on a friends still. Not too bad. I see my friends fermenting in a grey 20 gallon trash can. They have a couple airlocks on the lid. I looked at the bottom of these cans and they do not say hdpe. Is this a safe fermenter? I am limited on space and a few 5 gallon buckets to ferment in is taking to much space. Also, are you able to ferment in a galvanized can? Thanks!
Re: New guy from texas
Howdy, and welcome!
welcome to the forum
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
AFP-LA-15027
Welcome to the forum, if you have the space I think you will quickly outgrow that still. As far as the garbage cans for fermenting I believe you can get food grade liners for them that are cheap and work.
Thanks for the welcome. Here in corpus christi, everywhere I go, its aluminum pots. I am looking for 80 - 100 qt. They are expensive and I have to order one, even from a restaurant supply. As far as plastic liners, cant find any here locally. I do work for a beer company and kegs are plenty, but they ate all aluminum. Most plastic cans I find say pp or ldpe with the triangle and #2. I am making a basic pot still with a stainless dish on the lid and my column on that. Any advice on the fermenter? Gotta be safe all the way around! Thanks!
You might want to double-check those kegs because virtually all kegs in use today are stainless steel - even in Texas... Go with a SS keg...ecriner wrote:Thanks for the welcome. Here in corpus christi, everywhere I go, its aluminum pots. I am looking for 80 - 100 qt. They are expensive and I have to order one, even from a restaurant supply. As far as plastic liners, cant find any here locally. I do work for a beer company and kegs are plenty, but they ate all aluminum. Most plastic cans I find say pp or ldpe with the triangle and #2. I am making a basic pot still with a stainless dish on the lid and my column on that. Any advice on the fermenter? Gotta be safe all the way around! Thanks!
The guys at the warehouse told me they are aluminum. I will have to double check. Is a galvanized steel can ok to use?
ecriner wrote:The guys at the warehouse told me they are aluminum. I will have to double check. Is a galvanized steel can ok to use?
NO
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Gotcha! Thanks!
As Rad said, aluminum 1/2 kegs are rare, though the 1/4 and smaller are often aluminum. Big aluminum kegs get bent up too soon to be economical. Lightly rub a file on it- it'll scratch up aluminum and barely do anything to ss. Welcome.
heartcut
W. H. Auden
W. H. Auden
Thanks a bunch! They are stainless. Gonna try and grab me a couple.
Came into some luck today. I got me a 50 gallon, white, hdpe, drum.........for free! It was at a buddys house. Never been used. I cut the lid and cleaned it up with some water and vinegar. Letting it air dry for a couple days.
