Difference between heat sources?
beer-baron
Post by beer-baron »
Hi there,
Just reading up before I get into my first session.
I have a propane burner that I use to boil beer in.
Is this not suitable for distilling? Am I really running a bad risk?
dakotasnake
Re: Difference between heat sources?
Post by dakotasnake »
i use propane and i like it. just make sure you have enuff air exchange in your shed or garage.
today marks the dawn of a new error.
moonshine guy
Post by moonshine guy »
To each their own and what the have access to, as for myself, I have the power to run high wattages so I use electric. I do have a couple of propane burners that I use outdoors, but electric is safer and fast if you can do it!
Bayou-Ruler
Post by Bayou-Ruler »
beer-baron wrote:Hi there,
any open flame application when dealing with flammable substances runs a higher rick, but it is sited well for distillation. I use Propane
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
mtdew_mn
Post by mtdew_mn »
You want to make sure you don't have any leaks that could drip alcohol on the burner. Keep the distillate far enough away to prevent it from catching fire even if if your container spills or breaks or something.
You can be safe with propane, as long as you are careful. When you are setting things up take some time to think of anything that could go wrong with your setup.
Also, electric has its own safety concerns.. It is safer but you need to ensure that you are using a GCFI outlet.
2" Bokakob (1 foot with 4 foot reflux extension), Pony keg, and propane
junkyard dawg
Post by junkyard dawg »
one simple safety tip.
If you collect in glass jars as many people do, just put them into a small pot to contain the contents in case anything breaks.
Ya know? Instead of having the jar sitting on the counter or table top, put a small pot there and put the jar inside it. Just a little extra insurance.
this is the internet
moonshine guy
Good advise junkyard dawg, I do the same thing myself even though I run electric. Never can be to careful with this hobby!
I always have my collection jar in a bowl or baking pan that can easily hold the contents of my collection jars, and then some...
Mr.Brown
Post by Mr.Brown »
Great tip jyd. something that i probably wouldn't have come up with on my own until it was to late. Thanks
Anything i do or say here is purely hypothetical and for information gathering and sharing purposes only.
+1 on the pan idea, I am in the process of switching from propane to electric.
