new pot
Post your builds here.
Wild Turkey
new pot
Post by Wild Turkey »
after running the valved reflux twice i have decided to build a simple pot
here are scraps from the first build i will be using
World Class Home Distillation Apparatus-valved reflux
bellybuster
Re: new pot
Post by bellybuster »
Nice stash!
You're doing the exact opposite as me, I went pot first then valved reflux which I'm getting running now.
Wild Turkey
Re: new pot
bellybuster wrote:Nice stash!
how did it work out,i felt like i was controlling heat and had very good water flow and kept it good and cold but was still losing a lot of vapor out of the top
bellybuster
Re: new pot
i have yet to do an alc run with the offset. with the vinager run I was able to knock down most of the vapour but I'm already thinking of re doing my condenser coil to a dual coil. I'll try it as soon as I get my electric kettle finished.
My big thing is options, I'd like to have the pot for lower flavoured stuff and the reflux for neutral to make other stuff. Hindsight, I should have built a combo style still and have the best of both worlds in one package.
That idea is still in my head. Thinking I may remove the offset and mount it above the column and do a VM still.
Wild Turkey
Re: new pot
i built the" World Class Home Distillation Apparatus"valved reflux,if i had it to do over i would not have a built in condenser i would leave it free hanging and double what it called for,but as is before i use it again i hope to have added more condenser. main problem is height and top heavy,add much more and half way tru a run it will tip over
Wild Turkey
Re: new pot
got this far,and bad weather and lack of time,but question now should i go with a simple worm or inclosed condenser
LibertyFighter85
Re: new pot
Post by LibertyFighter85 »
with all the piping you have, I would go with an inline condenser. More effecient I think.
Sincerely,
LibertyFighter85
"Ain't nobody gonna work this damn hard anymore for some damn likker" -Popcorn Sutton
Wild Turkey
Re: new pot
that what i had decided around 3 feet of 3/4 inside 1 1/2
LibertyFighter85
Re: new pot
That sounds like plenty... I'm running 36" of 1/2" Copper inside of 1 1/2" PVC and it works great!
Sincerely,
LibertyFighter85
Wild Turkey
Re: new pot
i have done a lot of soldering/brazing and some welding. in my early days i popped a hole in i pipe a few times with a oxygen acetylene torch,but that was thirty years ago and most say i make a very good solder joint-so tonight i ruined two 1 1/2 inch fittings ..well actually four, two 1 1/2x1 1/12 x3/4 tees and two 1 1/2x 3/4 reducers..i have never seen 95-5 solder basically eat holes in copper before.i was using mapp instead of the torch kit because of low gas and used no flux just sanded parts very well- :x
i had the tees reducers were only $8:00 apiece but to replace with just the tees now is going to cost over fifty :cry:
southern traditions
Re: new pot
Post by southern traditions »
Same here. I started with a basic pot still, then added a thumper. I ran this way for about two months. I then built a double reducer reflux still with a 2" x 36" column. I reused my original 32quart boiler and now with a few minor mods its used as my pot still and my reflux still and I still use the thumper when running in pot still mode...
Learning to run the reflux still has definitely been a learning experience..
Martin
desertshiner
Re: new pot
Post by desertshiner »
I wanted to know how you attached that female pipe end to your "top" piece? Looks simple, and no sink strainer to mess with...
Wild Turkey
Re: new pot
that is a 2" union that i silver soldered with the oxygen acetylene torch,cap is ss plate cover from hotel
http://www.hotelrestaurantsupply.com/VO ... Ogodx24AGg" onclick="window.open(this.href);return false;" rel="nofollow
they come in at least two sizes -but it was what i had on hand and the less i have to buy... :D
Wild Turkey
Re: new pot
finally decent weather and a little time,in the same day..almost finished today
Wild Turkey
Re: new pot
another
Re: new pot
Nice looking build, Wild Turkey... :thumbup: A bit of overkill on that thermometer mount, but whatever floats your boat... :eh: Get that puppy cleaned and producing some tasty spirits... :ewink:
Wild Turkey
Re: new pot
rad14701 wrote:Nice looking build, Wild Turkey... :thumbup: A bit of overkill on that thermometer mount, but whatever floats your boat... :eh: Get that puppy cleaned and producing some tasty spirits... :ewink:
yea i know..i already had it ,it set on top of the column on the world class still.i did not solder it in on either.
i put the "t" in the column on this pot for a thermometer but not necessarily this one,and/or to deal with cleaning or packing.
and i am a believer in adjustment and dis assembly it has two unions now and will have three so parts can be broken down and while intact a little loosening and can change angles and re tighten
and thanks :ebiggrin:
