Help! Im desperate! Wiring heard a pop
If it plugs in, post it here.
diyftw
Post by diyftw »
Help, im desperate, I had just finished wiring this thing up.
I turned it on and after adjusting the potentiometer I heard a pop in the box. The middle wire to the potentiometer is grounded to the ssr.
I could really use some advice here. Do you think I blew my SSR?
Re: Help! Im desperate! Wiring heard a pop
Don't you have a meter/tester to confirm?
Looks like the service life would be very short anyway with not even a heat sink.
acfixer69
Post by acfixer69 »
Its wired wrong, looks like the pot switch shorted.
AC
diyftw
Post by diyftw »
The heat sync is hidden beneath the SSR
I Figured it out!! I wasnt using the correct terminals for the Potentiometer! ITS ALIIIIIIIIIIVE!!!
Prairiepiss
Post by Prairiepiss »
The case of the pot should be grounded. Not inevitable the three terminals.
diyftw wrote:The heat sync is hidden beneath the SSR
Ah,,,,thats a cute little one.
Soggy Bottom Boy
Location: Somewhere to the north of the.. ..Peoples Яepublik of Kalifoяnia
Post by Soggy Bottom Boy »
With no ventilation holes in your box, where is all of the heat going into the heatsink supposed to dissipate to??? The air in the sealed box is going to get hot, and your heatsink will get hotter and hotter, until, well, at the very least the life of the relay is going to be shortened or maybe it will flat out fail.
