My SSR
- crazyk78
My SSR
Hi All.
Please only post SSR related info in here...there is tons and tons of info around on other heating control.
I've bought the bits and pieces for an SSR and it doesn't seem to work...just wanted your opinions.
When I apply power, it doesn't blow up....phew! but I only get 240V on the output and it doesn't control with the pot.
Do these need a load to work?
What am I doing wrong...I've attached a photo for assistance.
Re: My SSR
Looks like it should work. SSR appears correct. Whats the ohm rating on the pot?
Only thing I see different than the way I did it is that I ran the ground from the power wire into one side of the heat sink and out the other side, and I didn't ground the pot like you have.
- crazyk78
Re: My SSR
Hi Bob,
Its a 2W 480KOhm pot.
I don't know it's doing my head it.
Does it need to be connected to a load?
Re: My SSR
Oh wait. you are reading volts. Pot changes amperage. If you have 240v, you will get 240v out. Check your amp reading (you need an ammeter). Amps x volts = watts. That's how you control wattage to the element
- crazyk78
Re: My SSR
Oh ! haha
Ok I'll test with the multimeter tonight.
Cheers, much appreciated.
- sambedded
Re: My SSR
pot controls both Amps and Volts. you just need to connect a load. For testing you can use any wattage incandescent lamp bulb
Re: My SSR
sambedded wrote:pot controls both Amps and Volts. you just need to connect a load. For testing you can use any wattage incandescent lamp bulb
Amps and watts. not voltage.
- sambedded
Re: My SSR
Read about Ohm law. You can't change an Amps for the same load without altering voltage.Bob Loblaw wrote:sambedded wrote:pot controls both Amps and Volts. you just need to connect a load. For testing you can use any wattage incandescent lamp bulb
Re: My SSR
Yes, it needs a load in order to function properly... For voltage just using a light bulb will work but that doesn't give it an amperage workout...
- sambedded
Re: My SSR
rad14701 wrote:. For voltage just using a light bulb will work but that doesn't give it an amperage workout...
It's safer to test on low amp load first. Then if everything is OK connect a full load.
Re: My SSR
Multimeters are worthless for testing SSRs. The best way to test an SSR is with a light bulb. An SSR needs to be load tested.
http://www.crydom.com/en/Tech/Newslette ... %20SSR.pdf" onclick="window.open(this.href);return false;" rel="nofollow
muddog
muddog
Simple pot still for simple likker
Moonshine and oysters, the breakfast of champions
"Don't turn on the lights cause I don't wanna see. Mama told me not to come" Randy Newman
- acfixer69
Re: My SSR
I can't see all the no's but that SSR could read voltage not resistance.
@ bob my ssr changes both amps and voltage. Does need a load to read anything useful.
AC
AC
Re: My SSR
It says 2W 470K Ohms...acfixer69 wrote:I can't see all the no's but that SSR could read voltage not resistance.
AC
Re: My SSR
Well, then perhaps I have wired my voltmeter incorrectly. My ammeter shows a drop when I turn down pot, voltmeter doesn't. algebra seems to suggests that (per aforementioned ohms law...) if the pot changes both at once then the impact on watts would be exponential (e.g. if V*A=W then 0.25V * 0.25A = .0525W) but I am clearly not an electrician...acfixer69 wrote:I can't see all the no's but that SSR could read voltage not resistance.
AC
- sambedded
Re: My SSR
P(Watt) = U(volt)*U(volt) / R(Ohm) = I(Amp) * I(Amp) * R (Ohm)
Where R is resistance of your heating element.
Re: My SSR
Hmmm. Physics was a long time ago! It appears I've been carrying around the DC formula for Ohms law all these years and applying liberally. Misses that resistance piece. I stand corrected, now to figure out how I effed up my voltmeter...sambedded wrote:P(Watt) = U(volt)*U(volt) / R(Ohm) = I(Amp) * I(Amp) * R (Ohm)
- crazyk78
Re: My SSR
Thanks heaps guys....well they're not going to let me out at lunch time so I'll test with a load tonight and let you know.
Cheers and appreciate the feedback. (from all the wiring diagrams I've seen I think it's wired correctly.)
Also, will I need a cooling fan in there if running a 4800W element?
I do have paste between the SSR and the heatsink.
- sambedded
Re: My SSR
If you mount your box vertically (for example hang it on a wall) and make enough holes in walls below and above the heatsink you are good without a fan.crazyk78 wrote: Also, will I need a cooling fan in there if running a 4800W element?
- crazyk78
Re: My SSR
Ah yes I understand to get the heat convection to go out the top of the box.
- crazyk78
Re: My SSR
Just an update.... I tested it with a fan ( didn't have a light bulb) and it worked a treat.
The voltage didn't change either. Must be just the current
Re: My SSR
the resistance is the only constant (somewhat) the voltage and amperage are tied together in relation to the resistance. The voltage didn't change because you must be reading it prior to the drop. Draw up a schematic of how you're wired and we can help you get it right. Or, there are a ton of schematics already here on the site.crazyk78 wrote:Just an update.... I tested it with a fan ( didn't have a light bulb) and it worked a treat.
- crazyk78
Re: My SSR
Hey belly. It works fine how I wired it.
The fan came on at about 50% and I could ramp it up and down from there. My understanding is AC needs a spike current to start so I guess this is why it started at 50%.
Re: My SSR
A fan uses an inductive load as opposed to a resistive load... A high powered light bulb, which has a resistive load, might give different readings than the fan... Or, as mentioned, the voltage issue could be a matter of where you are taking your reading from...
Re: My SSR
Do you not have a boiler yet?? Just hook it to your element.
- Jolly John
Re: My SSR
Found this schemetic, might be of use.
http://postimg.org/image/85j8ynzn1/" onclick="window.open(this.href);return false;" rel="nofollow
No one is completely useless.....they can always serve as a bad example.
Re: My SSR
- Jolly John
Re: My SSR
bellybuster wrote:
Cheers Bellybuster.
- crazyk78
Re: My SSR
It's all good in the end guys...It just needs a load to work.
In any case, I also tested it with my corded drill. Hooked the drill up trigger in, then dialled up the knob.
Whalla! now I have a variable drill !
