Newbie here!
Newbie here!
Hi everyone!
Completely new to the game, done a bit of reading and stuff and that's about it. Looking to build a still in the coming weeks.
I'm basically looking to make a neutral spirit, but it' the technical side of things that I'm most interested in. I'd like to eventually make a fully automated still that you basically push a button and walk away from (using a PLC).
As I said before I know nothing really about home distillation aside from what I've read. I do have a degree in chemical engineering, so I hope that helps From Aus!
Cheers
Cheers
- S-Cackalacky
Re: Newbie here!
Welcome to the forum. You might want to think long and hard about that "automated still" thing - especially the part about "walking away from it". There's some reading here that we consider "required reading" which are the links in my signature. You might also want to add the "Safety and Related Issues" forum to that list.
Good luck to you and stay safe.
Re: Newbie here!
If you're thinking about walking away from a running still then your degree in chemical engineering isn't worth squat... We take safety very seriously here, and you should too... If your previous education didn't teach you that, doing your mandatory research here will... Never leave a still unattended - period...!!!
Re: Newbie here!
Hello and welcome to HD, Lots of good mandatory reading here. Sorry I dont see any fun in running a fully automated still. Have fun and be safe.
Fail to plan == plan to fail
Re: Newbie here!
Thanks for the responses guys.
I think we may have gotten off on the wrong foot here. When I said "walk away from" I meant "not have to interact with". I certainly wouldn't leave anything with flammable vapour in it to do its own thing for a few hours.
The goal isn't necessarily to run an automated still, but more to learn the fundamentals of automatic control and develop logic for a PLC. This would include sending alarms when things start to go wayward and even fault shutdowns, but I will ALWAYS be there to ensure nothing goes wrong.
Da Yooper, when you say there's no fun in running an automated still, I agree. The fun and education is in developing/tweaking it, once I've done that I'll probably just run it manually.
So yeah, sorry if I gave you the wrong impression. If it turns out I can't do it safely (or it is prohibitively expensive to do it safely) then I simply won't.
- ga flatwoods
Re: Newbie here!
Noodrid you have to know what hou are doing first. After some years of practice you may know enough about it to automate but after that you may never wish to. Perhaps a flute build would perk your interest later instead. Be safe and enjoy the site whichever route you take.
GA Flatwoods
p.s. itmhas been done before and it does costs lots of time, sweat equity, and money.
GA Flatwoods
I am still kicking.
Ga Flatwoods
I am still kicking.
Ga Flatwoods
Re: Newbie here!
Yep, if you don't know how to run a still manually, and be fully experienced at it, complete with those intermittent hiccups, you're not prepared to design and build and program the associated automated processes... Put the idea on the back burner until you have a few years of manual operation under your belt... Literally multiple dozens of runs... If you've never seen anything even marginally go wrong, and adequately corrected manually, you won't be prepared to account for it in an automated way...
Re: Newbie here!
Don't know why you would want one you would walk away from, that is part of this hobby watching listening smelling tasting.Treat it like a good woman and she will treat you good if you don't give her the attention she wants and needs she will burn ya!
Buy the ticket and ride the lightnin boys !!!
Impatience is the root of all bad things in my book of makin likker!
The sound of a thumper is the heart beat of the rebel" Warden Pappy"
Re: Newbie here!
This was exactly the plan, and it will probably have changed by that time. The plan I mentioned above was a very long term one. To start with I just need to learn the basics and operate a simple still manually. Once I do that I may have so much fun (or difficulty ) that I throw the automation idea out altogether!rad14701 wrote:Put the idea on the back burner until you have a few years of manual operation under your belt...
Thanks again
Re: Newbie here!
My significant other calls it getting my mad scientist fix... Automation just wouldn't cut it...
Re: Newbie here!
I concur with that Rad it is an addiction!rad14701 wrote:My significant other calls it getting my mad scientist fix... Automation just wouldn't cut it...
- T-Pee
Re: Newbie here!
Aren't we modern alchemists?
al·che·my
noun \ˈal-kə-mē\
: a science that was used in the Middle Ages with the goal of changing ordinary metals into gold
: a power or process that changes or transforms something in a mysterious or impressive way
tp (and his spells)
al·che·my
noun \ˈal-kə-mē\
tp (and his spells)
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
