from nz new s/s collom buld
kiwi Bruce
Re: from nz new s/s collom buld
Post by kiwi Bruce »
Literally....you went through the ceiling ! !
tuf720
Post by tuf720 »
kiwi Bruce wrote:Literally....you went through the ceiling ! !
yeer sure did the shed needs a re plaster and mod the house to fit the still :twisted: priority
Excellent job, I'm jealous :thumbup:
tuf720
Post by tuf720 »
shadylane wrote:Excellent job, I'm jealous :thumbup:
thanks need still how to run it but will get there
Danespirit
Post by Danespirit »
Excellent...! :thumbup:
It runs as fine as it looks...
Don't worry...you will know how it behaves with just a few runs.
And if the spirits turn out a little bad (which i doubt), you have the advantage of re-running them...
StumpJuice195
Post by StumpJuice195 »
I'm a bit of a newbi in the flute world so correct me if I'm wrong. Shouldn't your downcomers on your plates have a cup or some sorts on the bottom to prevent vapor passing straight through. Looks like you have a bevel cut on the bottom and that's all. Like I said please correct me if I'm wrong or just missing something.
If your gonna be dumb you had better be tough !!!
pulsetech
Post by pulsetech »
StumpJuice195 wrote:I'm a bit of a newbi in the flute word so correct me if I'm wrong. Shouldn't your downcomers on your plates have a cup or some sorts on the bottom to prevent vapor passing straight through. Looks like you have a bevel cut on the bottom and that's all. Like I said please correct me if I'm wrong or just missing something.
Ok they will work just fine. The cut is below the bath level. If you use short down comersthat don't reach the lower plate you need a fluid trap to stop the bypass.
StumpJuice195
Ok, I guess I learned something. But still seems like you would lose vapor until the plates get flooded. Probably a minimal amount I'd say. Like I said I'm a newbi still learning.
pulsetech
Post by pulsetech »
They fill quick and from the top down.remember when they are filling it's the down comer that is filling the plate.
googe
Post by googe »
Your not loosing vapor, the vapor needs to go up to the reflux condenser, condense, then fall back down and fill the plate till it's full enough to create a lock on the downcomer, then your plates will be working 100%, only exception is cap plates, they can be pre filled with water, low wines ect and they'll work straight away.
"Homer J Simpson"
StumpJuice195
Very well explained googe. I understand now. Thank you
tuf720
Post by tuf720 »
new stuff carter head
seen if the hole is big enough
pythonshine
Post by pythonshine »
Nice! consider me jealous :mrgreen:
tuf720
Post by tuf720 »
pythonshine wrote:Nice! consider me jealous :mrgreen:
thanks
tuf720
Post by tuf720 »
heres a recent photo runing like a dream
tuf720
Post by tuf720 »
well changing the still up a bit
new packed section trying to polish it
plates
new water lines and dran to carter head
Swedish Pride
Post by Swedish Pride »
nah no good mate, best send it to me for modifications :P
Don't be a dick
tuf720
Post by tuf720 »
Swedish Pride wrote:nah no good mate, best send it to me for modifications :P
hahahah the old one may be lol
Hmmm... I like the patina look better than the spit shine, but that's just me...
Teddysad
Post by Teddysad »
It is a mighty impressive build (I have seen it in person)
Well done Tuf
You can lead a horse to drink, but you cant make it water!
You can lead a horticulture but can you teach a prototype?
Proverbs 31:6-7
tuf720
Post by tuf720 »
Teddysad wrote:It is a mighty impressive build (I have seen it in person)
Well done Tuf
cheers teddy yeer lots to run now need it going lol
waiting on fittings for flow meters and make some more bracing brackets and may change the parrot
tuf720
Post by tuf720 »
water lines are done a couple off welds and time to run
another bracket for safe keeping
tuf720
Post by tuf720 »
clean run hi charge off fores but ok
hellbilly007
Post by hellbilly007 »
Tuf, that's a gorgeous build. You've got some awesome skills
What size are the cooling water flow meters :?:
tuf720
Post by tuf720 »
they are 3/4
xyz123
Post by xyz123 »
That accent is a bit sketchy, what was the charge again?
Mikey-moo
Post by Mikey-moo »
By the power of Greyskull... that's beautiful!
tuf720
Post by tuf720 »
xyz123 wrote:That accent is a bit sketchy, what was the charge again?
70% ish
tuf720 wrote:they are 3/4
Sorry, I meant to ask what is the max and min flow rates :oops:
