from nz new s/s collom buld
- kiwi Bruce
Re: from nz new s/s collom buld
Literally....you went through the ceiling ! !
yeer sure did the shed needs a re plaster and mod the house to fit the still prioritykiwi Bruce wrote:Literally....you went through the ceiling ! !
Excellent job, I'm jealous
thanks need still how to run it but will get thereshadylane wrote:Excellent job, I'm jealous
- Danespirit
Excellent...!
It runs as fine as it looks...
Don't worry...you will know how it behaves with just a few runs.
And if the spirits turn out a little bad (which i doubt), you have the advantage of re-running them...
I'm a bit of a newbi in the flute world so correct me if I'm wrong. Shouldn't your downcomers on your plates have a cup or some sorts on the bottom to prevent vapor passing straight through. Looks like you have a bevel cut on the bottom and that's all. Like I said please correct me if I'm wrong or just missing something.
If your gonna be dumb you had better be tough !!!
StumpJuice195 wrote:I'm a bit of a newbi in the flute word so correct me if I'm wrong. Shouldn't your downcomers on your plates have a cup or some sorts on the bottom to prevent vapor passing straight through. Looks like you have a bevel cut on the bottom and that's all. Like I said please correct me if I'm wrong or just missing something.
Ok they will work just fine. The cut is below the bath level. If you use short down comersthat don't reach the lower plate you need a fluid trap to stop the bypass.
Ok, I guess I learned something. But still seems like you would lose vapor until the plates get flooded. Probably a minimal amount I'd say. Like I said I'm a newbi still learning.
They fill quick and from the top down.remember when they are filling it's the down comer that is filling the plate.
Your not loosing vapor, the vapor needs to go up to the reflux condenser, condense, then fall back down and fill the plate till it's full enough to create a lock on the downcomer, then your plates will be working 100%, only exception is cap plates, they can be pre filled with water, low wines ect and they'll work straight away.
"Homer J Simpson"
"Homer J Simpson"
Very well explained googe. I understand now. Thank you
- pythonshine
Nice! consider me jealous
Keep on keepin
Crankys spoon feedin: http://homedistiller.org/forum/viewtopi ... 15&t=52975
Read and live by em: http://homedistiller.org/forum/viewtopi ... =35&t=5090
Safety: http://homedistiller.org/forum/viewtopi ... 33&t=11187
thankspythonshine wrote:Nice! consider me jealous
- Swedish Pride
nah no good mate, best send it to me for modifications
Don't be a dick
hahahah the old one may be lolSwedish Pride wrote:nah no good mate, best send it to me for modifications
Hmmm... I like the patina look better than the spit shine, but that's just me...
It is a mighty impressive build (I have seen it in person)
Well done Tuf
Well done Tuf
You can lead a horse to drink, but you cant make it water!
You can lead a horticulture but can you teach a prototype?
Proverbs 31:6-7
Proverbs 31:6-7
clean run hi charge off fores but ok
Tuf, that's a gorgeous build. You've got some awesome skills
What size are the cooling water flow meters
they are 3/4
That accent is a bit sketchy, what was the charge again?
By the power of Greyskull... that's beautiful!
70% ishxyz123 wrote:That accent is a bit sketchy, what was the charge again?
Sorry, I meant to ask what is the max and min flow ratestuf720 wrote:they are 3/4
