Wrapping Sythetic Seals in PTFE Tape
Re: Wrapping Sythetic Seals in PTFE Tape
Using inked cardboard in the "everlasting" gasket is flirting with rule 8, synthetics.
Likewise, dont.
Here's a proof of concept for a better seal on non standards sized openings needing a gasket.
Take a length of PTFE tubing and split it lengthwise along one side.
Slip the split tubing over your stockpot rim and carefully trim so that the ends meet up when installed on the lip.
Voila. A simple, safe gasket for non standard sized openings. This example was done with 1/2" PP tubing only for the proof of concept and to illustrate how it works.
Likewise, dont.
Your comments are offensive. You're on my foes list.
- der wo
It will not good seal at the ends of the tubing.
And ptfe hoses are less flexible than pp.
- pythonshine
Wonder if you could heat/weld the plastic ptfe together?
Keep on keepin
Crankys spoon feedin: http://homedistiller.org/forum/viewtopi ... 15&t=52975
Read and live by em: http://homedistiller.org/forum/viewtopi ... =35&t=5090
Safety: http://homedistiller.org/forum/viewtopi ... 33&t=11187
- der wo
Me too. But ptfe fumes are very toxic. And anyway, you would need much and even pressure from the top that the ptfe compresses bit and seals.pythonshine wrote:Wonder if you could heat/weld the plastic ptfe together?
That's not PTFE tube it's PTFE coated tube, when you cut it the ends are exposed, who knows what the actual tube is made of.
As far as I know all PTFE is white, I assume the tube is not white because to coating is so thin.
I have used this to seal 3: sight glass with great success http://www.equalseal.com/PTFE-Valve-Ste ... s/2147.htm you can also get it from most hardware stores, sold in 18 inch lengths as PTFE valve stem packing. Just overlap the ends for a leaktight seal.
It's polypropylene tubing as I said in my post. It was a proof of concept.Johnny Walker wrote:That's not PTFE tube it's PTFE coated tube, when you cut it the ends are exposed, who knows what the actual tube is made of.
PTFE tubing comes in clear and white. We have hundreds of feet at my office we use for indoor air sampling.
PTFE tubing isn't coated. It's 100% PTFE.
You know what?buflowing wrote:Your comments are offensive. You're on my foes list.
Being born and raised in Pikeville, KY, I find the term "hillbilly" offensive as well, yet that is allowed to persist on these boards. Do a search for hillbilly engineering and let me know how many hits you get
Connotations of people who arent smart, well off, etc.
Do you see that slippery slope?
Sounds like you need a safe space, snowflake.
Bet you received lots of participation trophies growing up.
- corene1
- HD Distilling Goddess
Looks like a good idea to me if it 100% PTFE. Bet I could get the ends to seal with a small dollop of flour paste. If it is a stiff tubing you could immerse it in hot water to help form it to the existing shape. Certainly worth doing a test if you have the tubing in hand.
Yup. Flour paste will seal the seam.
We dont have 1/2" tubing at the office as the air sampling stuff is all 1/4" for swagelock.
I ordered 3 feet of 1/2" from US Plastics.
Take a look at corene's PTFE wrapped copper washer (gasket). After seeing her's I made one to replace my cardboard one, a excellent permanent solution.
The term "hillbilly" will only bother you if you let it... If you don't consider yourself a hillbilly then your argument is moot... But if the shoe fits, wear it proudly... You're the one pigeonholing yourself, not anybody here...Sgt Stedenko wrote:You know what?buflowing wrote:Your comments are offensive. You're on my foes list.
I've been following your recent posts and you sure do seem to think you've got all the answers and have no problem belittling members here without knowing who you're talking to, and in some instances not even knowing what you're talking about... Keep calling people derogatory names and you might just end up in Read-Only mode... It's happened due to far fewer offenses than I've read from you in just this one topic... Take a chill pill, have a drink, and relax because it may be you that needs advice someday and if you piss off those with the answers the silence could be deafening...
Nuff Said...
- pythonshine
How did the gasket work? Had a feeling you'd be here rad....I used to weld plastic for a drainage Co, take a rasp to the edges get em nice and rough, heat till the burs start to melt then press the ends together. Sharp knife to the balled edge. Now that was not ptfe buit should work...no flame directly on the plastic. Let me know if anyone tries it.
Keep on keepin
Hmmm, I have a question. I see there is a large membership, the OP asked what HD thought on the subject manner. My question being, who is HD and how do 'they' make the decisions?
Getting back into stilling after a few years off.
- pythonshine
Home Distiller.....HD......everybody......not sure what your asking?
Keep on keepin
From what I have read, it is the members that make the rules, apart from UJ's have to rules. I suppose what I am asking is who is it that says that one thing is OK and others are not. Who makes that call?pythonshine wrote:Home Distiller.....HD......everybody......not sure what your asking?
- pythonshine
Hmm...that is a slippery slope.. I am not knowledgeable enough to say, however I do know enough to say this is not the thread this should be discussed. Start your own thred, but be warned, you might not like the outcome.
Keep on keepin
Right, thanks.pythonshine wrote:Hmm...that is a slippery slope.. I am not knowledgeable enough to say, however I do know enough to say this is not the thread this should be discussed. Start your own thred, but be warned, you might not like the outcome.
- thecroweater
Admin make the call, just like every forum ever. A quick search will bring up some resent threads discussing synthetics and the burden of proof, the same search will bring up the stuff discussed and how to talk about it. That is if it's not shown to be safe then the board are unlikely to proved it and it can not be recommend herefreaky_cutout wrote:From what I have read, it is the members that make the rules, apart from UJ's have to rules. I suppose what I am asking is who is it that says that one thing is OK and others are not. Who makes that call?pythonshine wrote:Home Distiller.....HD......everybody......not sure what your asking?
- thecroweater
Listen champ the rules are about synthetics in CONTACT with vapour or spirit. Anyone said to me this hobby is only for the wealthySgt Stedenko wrote:Nice.Monkeyman88 wrote:Easy. Unwrap a very used everlasting gasket. I've done it twice and both bits of cardboard where in the same condition they were when first wrapped. I used a section of cereal box with colours still on and they hadn't changed at all.
Do you know the chemical composition of the ink on your cereal box?
A PTFE gasket is about a buck.
Trying to afro engineer a gasket with a questionable core is priceless.
Like others have said.
If you cant afford this hobby, stick to knitting.
