You might have cookie issues on the site. After the install, the site had the index page messed up, I fixed that. Then the new php engine was not supporting compression, so I removed that. Well to do that, I had to remove compression code from the cookies also. That got the site working, short term. UJ then rebuilt the php engine, adding the compression module to it, and the compression code was re-added to the parent sites php code.
For a while, I was seeing some compression errors on the httpd-errors.log file. It was clients coming in with non-compressed cookies, and the site wanting to decompress them.
At home right now, I am seeing the "It Works!" page when I simply go to homedistiller.org I do not know WHY that is happening, trying to refresh my browser is not fixing it. That file has been removed, so it has something to do with the caching on this web browser. I will have to likely clear the cache. Now, on this browser, I can easily go to homedistiller.org/index.php That brings the parent site right up, and works fine.
Now, for clearing the cookies (if that is your problem). Go to this link :
http://homedistiller.org/intro/user_config.php" onclick="window.open(this.href);return false;" rel="nofollow It is the very first link on the Intro menu of the parent site. Click on the "delete all cookies" button. I hope that clears up the problem you are getting. The parent site uses cookies to try to remember which page you are on, on each menu. It is very hard to get all of that right. It does an OK job most of the time, but due to a lot of technical things, it really is NOT an easy task to get working all the time, and working the same within all browsers.
H.
