Is any water soluble Flux fine for building?
Is this solder safe for building?
Thanks in advance
Is this solder safe and hopefully last Flux question
dendog33
Re: Is this solder safe and hopefully last Flux question
You should always check the MSDS of any solder or flux you intend to use... We've discussed solders and fluxes many times so you should be able to find the information needed by doing a few searches... If you use what most here use you will be safe... Any deviation puts all of the responsibility on you...
dendog33
Thanks for the reply, I will search more. I find the search option a bit clunky.
I have used your calcs many times. Thank you sir
Use the Forum Google Search... Just append your search term to the end of what displays by default... phpBB's Search is somewhat limited in flexibility...dendog33 wrote:Thanks for the reply, I will search more. I find the search option a bit clunky.
dendog33
Wow, can't believe how long I have been trying to use that other search and how much time I wasted thanks rad
