Bombay Sapphire Gin
n1cod3mus
Bombay Sapphire Gin
Post by n1cod3mus »
I have had a lot of people asking me if i make Gin, now I dont drink it so it wasnt something I intended to make so I did some research and tried a few experiements which mostly failed, such as making essences.
I have made a steeped gin as well but I havnt done a write up for it like i did with this one, so this is a Bombay Sapphire style Gin, its made with all the same ingredients, and using the vapour infusing method.
http://www.instructables.com/id/Making- ... r-Infused/
the feed back I have had is that its not far off Bombay Sapphire.
there is one thing that does puzzle me and you guys might be able to answer it, even though the distillate is clear and also the water added is clean and clear, often bottled water or distilled water, for some reason when I add the 2 together it goes cloudy. I have no idea why, it doesnt affect the taste or anything.
Elizabeth : "so your just going to sit on the beach drinking rum?"
Jack: "welcome to the caribbean love"
UtahViking
Re: Bombay Sapphire Gin
Post by UtahViking »
Interesting I have a big ole juniper bush in my backyard and I love gin so I have been looking longingly at it so I appreciate the write up. Not familiar at all with infusing so I'm interested to see the feedback here.
If someone suggests you do some research. Don't think of it as an insult, consider it a challenge.
Novice Distllers Shopping List http://homedistiller.org/forum/viewtopi ... 15&t=37201
n1cod3mus
Post by n1cod3mus »
well i dont drink gin but i have done both steeped and infused and the people i gave them to all prefer the infused, it seems to give more flavours.
I am very pleased with how it has turned out being the first vapour infused gin i have ever done. the people I gave it to have said it is very close to bombay sapphire.
copperhead46
Post by copperhead46 »
When mine did that I was told that it was because I added water to the whiskey, and you are supposed to add whiskey to the water :crazy: It does make a difference though, so you might try that.
I ain't here for a long time, I'm here for a good time...........
to hell with the red wine, pour me some moonshine.
Black Eye
Post by Black Eye »
I've heard about adding water to the whiskey will make it cloudy. I've been fortunate so far, and I've done it both ways with good results. I'm wondering if it had something to do with the ABV? Most of the whiskey I've proofed with water was oaked. Never really comes off the pot much over the 130's. I usually pick what I want to save for drinking and mix it, which brings it down in the 110's-120's. I oak it between 110-120 proof and then proof down to 94-98 give or take a few before I bottle. It's always been good and clear, even the stuff I leave white. Maybe once you get up to a higher ABV is reacts different when you're adding a larger volume of water ??? Maybe, I just have good luck?
Only way to drink all day... is to start in the morning
n1cod3mus
Post by n1cod3mus »
it seems to happen with a low amount of water as well, I added 100ml water to 650ml of spirit and it still went cloudy.
I will try it the other way around but that doesn't make sense, in fact I will try it now
n1cod3mus
Post by n1cod3mus »
as i expected it made no difference
With water and spirits the same temperature you should be able to slowly add spirits to the water, allowing it to gradually become miscible, the chance of clouding is greatly minimized... However, if there are excessive heads or tails in the mix all bets are off...
n1cod3mus
Post by n1cod3mus »
rad14701 wrote:With water and spirits the same temperature you should be able to slowly add spirits to the water, allowing it to gradually become miscible, the chance of clouding is greatly minimized... However, if there are excessive heads or tails in the mix all bets are off...
maybe that's the cause too much heads/tails, also don't know if it makes a difference but I am using bottled water, even when I used distilled water it seemed to do the same
frozenthunderbolt
Post by frozenthunderbolt »
Gin that is cloudy when you add water to it is due to the oil content of the herbs and spices used. It is the 'Louche'
n1cod3mus
Post by n1cod3mus »
frozenthunderbolt wrote: Gin that is cloudy when you add water to it is due to the oil content of the herbs and spices used. It is the 'Louche'
so effectively there's nothing i can do about it
Druss
Post by Druss »
what if you add the infusion slowly after mixing the water to alcohol ratio of your choice?
frozenthunderbolt
you can add some more neutral so there is less oils per unit of alcohol, slight drop in flavour, but may well fix your problem
Bogdan
Post by Bogdan »
OK the reason the gin goes cloudy is that in the ABV you have not all the oils remain dissolved and those that are no longer dissolved become an emulsion with the water. The solution is to run your still in such a way that your output is at the ABV you want to bottle your product. When you do this you only have the quantity of oil which can be dissolved. This is the way the larger commercial distillers do it and probably the only reliable way to get clear product since it is extremely difficult to quantify the oil content of the botanicals which vary from batch to batch.
Bogdan
n1cod3mus
Post by n1cod3mus »
Druss wrote:what if you add the infusion slowly after mixing the water to alcohol ratio of your choice?
its vapour infused so thats not possible
n1cod3mus
Post by n1cod3mus »
frozenthunderbolt wrote: you can add some more neutral so there is less oils per unit of alcohol, slight drop in flavour, but may well fix your problem
not a bad idea as long as it doesnt affect the flavour too much, might give that a go
n1cod3mus
Post by n1cod3mus »
Bogdan wrote:OK the reason the gin goes cloudy is that in the ABV you have not all the oils remain dissolved and those that are no longer dissolved become an emulsion with the water. The solution is to run your still in such a way that your output is at the ABV you want to bottle your product. When you do this you only have the quantity of oil which can be dissolved. This is the way the larger commercial distillers do it and probably the only reliable way to get clear product since it is extremely difficult to quantify the oil content of the botanicals which vary from batch to batch.
Bogdan
kinda hard to do that though isnt it? as the alcohol vapour would come out first, the only way I could get something close maybe would to run the heater at full pelt
Bogdan
Post by Bogdan »
Bogdan
Yes its difficult to get the output at the finished ABV but not impossible if you are using a large pot still which is very inefficient. The deal is you have to be driving it had enough to get lots of water evaporating off at the same time the spirit is boiling off. It helps if your wash is relatively low ABV as well. This is the reason dedicated gin stills are specifically designed to do this job.
Alcophile
Post by Alcophile »
I made this as my first distillation (largely because my other-half likes Bombay Sapphire), though I added a some oats as a local distillery uses them and I liked their product's mouthfeel.
The result is pretty good (stripping run with T500 column with my grainfather, then spirit run with the Still Spirits alembic and the botanicals basket).
However.. there is a sweetness to the gin (at least as a G&T), which I wasn't expecting.
Can anyone suggest where the sweetness is coming from so I can reduce it next time?
Many thanks for any suggestions!
Neil
If your stripping.....then loading the low wines into the t500, then doing the spirit run while at the same time using the botanicals basket , how are you making cuts if any?
Alcophile
Post by Alcophile »
Cuts on the stripping run, essentially taking out foreshore/heads, not really any tails. Then my take is that no cuts are needed on the spirit run, though checking that for smell/taste and seems OK.
If that's not right I'd like to hear.
StillerBoy
Post by StillerBoy »
Will take a shot in the dark on this one.. stop using oats in your wash, and it's probably the oats that giving the sweetness you don't like.. in some whiskey, yes the flavor of the oat often helps..
If you are adding oat to your neutral, and using that neutral for the gin, then are using a flavored neutral which is not recommend, as that not the type of neutral for gin making I use..
Mars
– Albert Einstein
You can't make proper cuts on a stripping run, it's just not possible.
Try stripping....then a proper spirit run with proper cuts......then distill again with your botanicals to make the gin.
Alcophile
Post by Alcophile »
Interesting, I would expect that a reflux columns the best way to cut out the unwanted portions of a distillation, why would that not be?
Then a spirit run should have minimal "nasties" in it - is that not correct?
A strip run is not a spirit run , regardless of what still you use.
Alcophile wrote: Tue May 12, 2020 1:51 pm not really any tails.
If you are basing that on what the t500 manurfacturer says....or the sales man told You, then you have a lot to learn.
Ain't a still on earth that wont make tails.
StillerBoy
Saltbush Bill wrote: Tue May 12, 2020 3:31 pm Ain't a still on earth that wont make tails.
I thing you wanted to say a fermentation that won't make tails.. still don't make tails, they help in the separation of the tails.. and no matter what style of still head you are using, there's always cuts required to be made..
Mars
– Albert Einstein
OK then, There is not a still in the world that wont let tails through if its run long enough and far enough into the run.
Alcophile
Post by Alcophile »
Basing it on smell and taste, couldn't discern any difference towards the end of the run from the reflux column, maybe I didn't run it far enough to find the tails, but output was pretty slow by the time I stopped. It was a sugar wash so maybe less tails than some washes.
However I'm new to this and lots to learn, all information, opinions & advice very welcome.
Alcophile wrote: Wed May 13, 2020 12:21 am... It was a sugar wash....
Ah ha! That’s where your residual sweetness came from, especially if you started with a high OG (alcohol potential greater than 10%).
