Updated calculators by Haggy
Uncle Jesse
Site Admin
Post by Uncle Jesse »
Hiya,
Haggy has updated his Packed Reflux Column Calculator https://homedistiller.org/wiki/htm/calc ... olumn.html
He has also created a new Shotgun Coil Condenser Calculator https://homedistiller.org/wiki/htm/calc ... enser.html
Both are added to the HD Wiki Calculators page. https://homedistiller.org/wiki/index.php/Calculators
As always, thanks for your excellent work, Haggy!
Chauncey
Re: Updated calculators by Haggy
Post by Chauncey »
Yes!!!!!
Haggy kicks ass
quadra
Post by quadra »
Agreed! Haggy thank you for all of your work :clap:
haggy
Post by haggy »
Thanks, all, I will keep on doing what I can.
For more information on Packed Reflux Column stuff, go to this thread:
For more information and several examples of the New Condenser Calculator, go to this thread:
The New Condenser Calculator has several options. You can study / design different types of condensers under different run conditions. Options you can specify are;
1. Shotgun condensers or Dimroth condensers
2. Stripping operation PC or a Reflux Column operation
3. For the Reflux Column option - The RC ( deflagmater ) or the PC
4. For the Reflux Column option - Total reflux ( 0 takeoff ) or Steady operation
5. Search - Calculator finds the cooling water flow rate for a deflagmater
where the condenser heat transfer equals the heat given off by the condensed reflux
6. No Search - Calculator uses the specified cooling water flow rate
You supply input data on the condenser design, the operating conditions and the cooling water flow rate and inlet temperature.
Try it - ask questions - give feedback
haggy
