sweetfeed whisky
Blue82
Re: sweetfeed whisky
Post by Blue82 »
So my sweefeed mash has been sitting now for almost 4 full days. Air lock is still releasing co2 about every 4 seconds. Took the lid off and man it smelled like old sour beer and was a bubblin like simmering water on a stove. Didn't get a hydrometer reading when I started due to it not being delivered yet. Took a reading today and it is at 1.010 and theres about a 1/8 inch layer of grain sitting on top (wash looks like murky water). Best I leave it set for a another day or so? Any thoughts would be appreciated.
modified9v
Post by modified9v »
Blue, if it were me I'd wait. I like to see the cap fall and hit .998... almost there. However, I have run it early and noticed no difference in flavors.
Modman
Ghost
Post by Ghost »
Agreed - let it sit and finish out. Move it into a cold place once its done for a couple of days and this will help clear it right up.
Forbidden in Heaven and Useless in Hell ....
bigbuck
Post by bigbuck »
is it ok to add more liquid molasses to the sweetfeed wash??? i know molasses has a very good sugar percentage and is cheaper than sugar when you buy it in bulk,going to play around with this,just thought maybe someone has already tried,if so what are the results???
jeepkidd
Post by jeepkidd »
Update on the TSC - Rolling Acres - MR Sweet
It has been fermenting well and smells good overall, but I think the "Wheat Shorts" which were listed were pretty much just straw, so it has a bit of the straw smell to it. I'll update after running it, but because of these Wheat Shorts, I'm going to try another feed store to compare, even if this stuff gives a good taste.
bigbuck wrote:is it ok to add more liquid molasses to the sweetfeed wash??? i know molasses has a very good sugar percentage and is cheaper than sugar when you buy it in bulk,going to play around with this,just thought maybe someone has already tried,if so what are the results???
Why would you want to try boosting the %ABV of the recipe when doing so will only cause more foreshots, heads, and tails, to be produced and less additional hearts, proportionately...??? Molasses has roughly 40% fermentable sugar by volume... Remove the greed factor and you'll increase the success rate...
bigbuck
Post by bigbuck »
sounds good,thanks for the quick reply rad,just thought i would ask because i have so much molasses at my disposal,the deer love it in the winter time!!!
steve2md
Post by steve2md »
with all the extra molasses, why not make rum?
I told the officer "I have my .45 on my hip, a 9mm in the console, and my shotgun under the seat" He said "Damn! What are you afraid of?" "Nothing" I replied...
SwampFox
Post by SwampFox »
After my first batch of corn meal mash being a bust and dumping the lot, I found success in this SF mash. Did a stripping run and couldn't wait until I had more low wines and did a spirit run. Extremely happy with the results. Did a hot set back for generation 2 and it was going like gang busters until today and really slowed down. Got a second batch of Gen1 going in another fermentor the following day. Think I did ok on my cuts too. Did the three step approach. I only collected 100ml per jar and then smelled, tasted, and hydro'ed them. Got some on oak and some white. Been itching to try some that I put on oak 2 days ago...... Already has a nice color and a great smell to it!! My spirit run took forever! From here on out, think I will wait until I have several batches of low wines before doing my spirit run. Only bad part now.... Snow is all gone! Gonna have to buy ice! Keep you posted on progress and thanks all for the help.
SwampFox
Andy Capp
Post by Andy Capp »
I have done something similar.
I used equal parts corn/oats/barley and a cup of molasses per 28lt total wash.
i stripped 3 gens( sour mash )for a spirit run then replaced some grain and added another cup of molasses for the next 3.
the results are very encouraging.
gives a real nice light rumsky flavour that we are happy with after 6 months aging.
will be doin more of this but will use new charred oak instead of used oak for aging.
A hangover is when you open your eyes in the morning and wish you hadn't.
TheRevDr
Post by TheRevDr »
If you mean replace some of the sugar with molasses, it will just be more like rum and even less like whiskey. If you use all the sugar and add more molasses, you could start stressing out the yeast causing off flavors.
blackedout
Post by blackedout »
I'm about an hour into my first run with my pot still. things are going great! the temp is at 199.1 and I'm getting about 3 drops per second
Blue82
Post by Blue82 »
blackedout wrote:I'm about an hour into my first run with my pot still. things are going great! the temp is at 199.1 and I'm getting about 3 drops per second
I'm also running my first ever. Tossed first 150ml. Proofed the first 200ml after that was was about 140 proof. Turned my heat even lower. Getting about the same 3 drops per second. Smells like sour apple candy
blackedout
mines not that strong, my first jar was about 115 proof. second jar is 105 proof. I'm trying to keep a nice steady heat that slowly increases the temp. and if i turn it down even a little, the temp starts to drop. but i don't want to get more water than alcohol, which may be my problem.
Blue82
Post by Blue82 »
Just proofed second jar. 130 proof.
modified9v
Just sampled some product that has been oaking a week. Thinking I dipped too deep into the tails. I can really taste it and smell it as compared to the previous generation run. Thinkin' I got greedy. Will time take care of this??? Our previous product has been very drinkable on a cube of ice... this stuff is a bit too full of sweet feed flavor. Amost has a 'straw' taste to it. Hmmmmmmmm.
blackedout
i finished my first run, i got two jars of hearts. i set my still up again, with the heads and tails added, and then my silicone seal in my condenser started leaking. so ill have to wait for it to harden again, and run it tomorrow night.
Blue82
Post by Blue82 »
Whole batch taste like rubbing alcohol. Gross. Disappointed. Wonder what I did wrong. Started at 140 proof then the last one I collected was 70proof. Smells and tastes like the alcohol you would get for cuts and wounds
steve2md
Post by steve2md »
put coffee filters over the top of your jars and let them air out for a day or two, then smell and taste again. You'll see a difference
blackedout
i have paper towels over mine, and mine dont smell or taste very good either.
on1wheel01
Post by on1wheel01 »
Mine is also the same. Smells and tastes horrid. I plan on mixing it with my Ujssm and double distilling it all. That should take care of it I would think. And hopefully not ruin the whole batch. I only have 2 quarts of the sour mash(mine was from pellets). I figure this way it gets rid of it and helps boost my other.
Blue82
Post by Blue82 »
Gonna mix mine together to proof it down and make Apple Cinnamon out of it. Gonna try corn next
blackedout
Blue82 wrote:Gonna mix mine together to proof it down and make Apple Cinnamon out of it. Gonna try corn next
i think I'm going to do corn next as well.
Blue82
Post by Blue82 »
since i had never tasted moonshine before, i went to the store and bought a bottle of moonshine from my local liquor store. tastes just like the stuff i made. disgusting. My moonshine experience is done lol. Was interesting, just not worth the time for me.
Ghost
Post by Ghost »
Its not for everyone! Good luck in your next venture.
smokindave
Post by smokindave »
Blue82 wrote:since i had never tasted moonshine before, i went to the store and bought a bottle of moonshine from my local liquor store. tastes just like the stuff i made. disgusting. My moonshine experience is done lol. Was interesting, just not worth the time for me.
I am somewhat disenchanted as well, as I expected to get some better results than I did to start. I am currently flavoring some sweetfeed on oak chips and some partial mash wheat whisky on oak chunks. It is not disgusting, but I also would not trade it for some good bourbon that is readily available at any liquor store. The flavor is not anywhere near what I would call better than any average whiskey I have had. Maybe a lot of it is the barrel aging, and I cannot begin to replicate that on my budget. And, would I want to age something I made for 8 years.......I just do not see that happening.
It is a lot of time investment, and so far I can buy some $20 bourbon that tastes better, IMHO. Time will tell. I am going to stick with it long enough to get some 6-8 months of age on my oak soaked products. If it still tastes like a stick, or like everclear, I will probably sell the still on Ebay.
2" Bokakob w/ 5 Foot Column - 15.5 Gallon Keg Boiler. Large supply of 5 Gallon Pails........
Ghost
Post by Ghost »
Guys I will say this - I could easily compare what I make now and then compare what I made when first starting out and tell a world of difference! Its night and day. In fact I can remember my first few runs - yeah it wasnt all that great. Its not a easy hobby for sure - time, money and effort are more than most want to spend.
smokindave
Hey Ghost,
I was wondering the same thing, but I don't know what I would do differently. I am following the recipes to the letter, and I run my still pretty well I think. It is a 2" boka. I have been running it detuned, and I am wondering if I would like it better with a potstill head for whiskey. But, I have read that a lot of guys make whiskey on a detuned boka. I think, in general, I just do not really like the taste of white dog sugar head liquor, for lack of a better term. My cuts could get better for sure, but I think even the middle heart cut of my sweetfeed is just grainy and sweet......no real complexity on its own.
And, from what I have read, it is not very easy to age it and have it stack up to even a run of the mill bourbon. I am not giving up yet, as I have yet to do an all grain bourbon. But if I try that, and don't like it, I can't say I will do too much more whiskey when I can buy Evan Williams Single Barrel for $22.
My partial mash wheat germ was better on the spirit run tasting, but I blended in too many tails, so I think that was just a failure on my part. I will probably just redistill most of that with some feints and try and make a neutral for vodka, etc.
With the sweetfeed, I just can't see any depth of flavor building. Has anyone made sweetfeed and aged it for however long, and can honestly say it has a better or as good as whiskey flavor than Maker's Mark or Jim Beam Black, etc. That is all I am really looking for out of this hobby. Something comparable. If it will happen over time, I will give it my best, but so far I am getting discouraged with each test sip I take.
blackedout
i think it may just be the sweet feed. what recipe should one try to get a basic alcohol taste with a pot still? i think the sweet feed just tastes a little weird and gross.
DuckofDeath
Post by DuckofDeath »
Not sur ewhat you did wrong. Mine smells and tastes awesome! I use a hybrid flute still and pull off at 185 proof. I may try pulling some packing and try for 180.
