DAD300 wrote:I didn't start this post, but jeezzzz...LOL...don't help them!
You get the idea here...you nailed it. Understanding copper in a still is as important as any of the other components. And I have went out of my way to not want all copper out...just the GD take off and Descending side...
If you didn't have a still and I could show you how to procure and build a SS still cheaper, faster and with no soldering, a still you could add all the copper you waned to the ascending side...would you?
I get hung up on it, because the Traditionalist want to bury the subject! And nobs get copper boka/liebig instructions without a warning label!
I know there are a few who would stick to copper because they want the look of copper. And again, if they understand it...fine.
Gee whiz some people don't get it, there is nothing wrong with stainless steel in the descending path but neither is there any problem with copper and here is the reason stated over and over and over and over again. If there is adequate copper in the ascending path it will not matter what is in the descending path it really is that simple, if there is an inadequate amount of copper
eg an all stainless still, then that still is not suitable for producing any consumable product. You are asking people to warn noobs about a problem that does not exist unless they have an inert still , then they have a still with potentially serious problems. Any cyanides, urethane, sulphides and sulphur compounds are going to pull straight through that sucker, something that will not happen with a copper or mostly copper still, recognizing this undisparageable fact does not make you some sort of luddite, it makes you informed
The Butchers Apron wrote
There's no need for the sarcasm. If you don't like what I post don't read it. It was an honest mistake.
no sarcasm inferred I happen to really like that blog a lot I was just letting you know it has been posted and discussed on here many times should you wish to search and read the discussions
My point is copper is the most important material in a still, to argue for its removal from the distilling apparatus simply shows a deficiency in understanding the distilling process and the very important roll copper plays in that roll.
Now if you were to propose that fully inert stills should
not be discussed on the forums I think you might have a very valid argument heck you could even use most of the same links
