Sallgudbitter wrote:Sorry miss-understood things and wanted to be sure it was clear. It was clear as mud to me apparently....
B
Sent from my SAMSUNG-SM-G870A using Tapatalk
B
Noone chars at 400. But what temp has the wood 1cm under the surface, if you hold a propane torch on it X seconds? Perhaps 400. But how long you need the 400 to get the vanilla? What do you get with longer or shorter 400?Hillbilly Popstar wrote:I understand that. But who chars at 400 degrees?der wo wrote:Does that mean, all the whiskeys aged in untoasted only charred barrels don't have those flavors?Hillbilly Popstar wrote:I believe that chart is more about toasting rather than charing. There's a big difference.
Definetely no. Or works it like "ok I want maximum vanilla, so I set my oven on 400°F and the longer I wait, the more vanilla I get"? No. A short toast at 400F will taste oaky, a long toast will have burnt flavors. Same at 300F (needs a bit longer) and 500F (needs shorter). The main difference between long 300 and short 500 is, that with short 500 you have more different toasts in the wood, outside dark, inside light, IF the wood is thick enough for that. That's why sticks are more recommended here than chips. More complex taste.
I found the chart very interesting, because the general principles (the sequence of the tastes) are important of course. But that's all. Its practical use is overrated imo.
Maybe that is part of the reason the whiskey we can make at home is so easily superior to commercial products?der wo wrote:Noone chars at 400. But what temp has the wood 1cm under the surface, if you hold a propane torch on it X seconds? Perhaps 400. But how long you need the 400 to get the vanilla? What do you get with longer or shorter 400?Hillbilly Popstar wrote:I understand that. But who chars at 400 degrees?der wo wrote:Does that mean, all the whiskeys aged in untoasted only charred barrels don't have those flavors?Hillbilly Popstar wrote:I believe that chart is more about toasting rather than charing. There's a big difference.
The chart is about wood and temperature. But it's unscientific, because there is no info on the duration of heating or the thickness of the wood. Without a detailed description of the experiment, this chart has only a small relevance.
I hope I understand it right, but as far as I know, the development of the tastes from the wood using heat is a continous degradation. It's not like "it's 400, so there will be vanilla". More like "it's getting hot, so the oaky flavor gets sweeter, after a while more and more vanilla, then toasty and burnt".
Even if it would be true, that if you hold the 400, you will never reach the almond and acrid tastes, not after 24h toasting, what would be the practical consequence? Nothing (except your kitchen is smelling better than your whisky). Because no distillery uses barrels toasted at 400. All use open flames and they do it onesided after coopering. So the heat is uneven, on the surface always more than 400 on the outside always much less. Probably they can control much, for example they found by experimenting, that a special combination of temperature and duration forms somewhere i the wood a relative thick layer vanilla taste, so this is the vanilla barrel toast. But even if you get detailed infos from them, how to adapt for your own 53gal barrel without the same torching machine? Or a smaller barrel, badmobarrel or sticks?
I've yet to make anything that is nicer that the commercial stuff I buy...Hillbilly Popstar wrote: Maybe that is part of the reason the whiskey we can make at home is so easily superior to commercial products?
Is it easy?Hillbilly Popstar wrote:Maybe that is part of the reason the whiskey we can make at home is so easily superior to commercial products?
Yes. I think we all know it now.Hillbilly Popstar wrote:Sent from my SAMSUNG-SM-G870A using Tapatalk
Yes, I just have to click the little box. I never think about it and didn't know it was annoying. It's automatic.der wo wrote:Yes. I think we all know it now.Hillbilly Popstar wrote:Sent from my SAMSUNG-SM-G870A using TapatalkIs it possible to stop this info under all your posts?
Sent from my REAL-C0M-PUTER using Firefox
It IS annoying to have an advertisement in every post made by Tapatalk...!!! In fact I have been tempted to see if it would be possible to strip those lines from rendered pages before they are sent from the HD server... I know it can be done because I've written similar code in the past... It's not like HD is getting paid to have the advertising here and Uncle Jesse has denied several entities offering to advertise here over the years... Let's keep HD Ad-Free...!!!Hillbilly Popstar wrote:Yes, I just have to click the little box. I never think about it and didn't know it was annoying. It's automatic.der wo wrote:Yes. I think we all know it now.Hillbilly Popstar wrote:Sent from my SAMSUNG-SM-G870A using TapatalkIs it possible to stop this info under all your posts?
Let's not continue to clutter up the thread with this there are other places to discuss it. One thing I will say is the apathalk message is a blatant spam ad that is not encouraged here so if you can turn the spam off please doHillbilly Popstar wrote:The way I see it, the owner of this forum chose to support Tapatalk. So anyone that takes issue with it shouldn't take it up with me.
Sent with love from my Springfield XD .45, tactical edition! c(-;
One thing I can say...it's not easy..Maybe that is part of the reason the whiskey we can make at home is so easily superior to commercial products?
Arrogance is the wrong term. I think you misunderstood the intent of my post.Danespirit wrote:+1 Thecroweater.
Definitely, I made a lot of mistakes, even though I was reading till my eyes bleed.
No distiller is better than the last batch he produced...
I'll leave the constructive criticism to others that tasted my product.
By paying attention to their words, I can improve my skills.
Another way is to read the wise words from experienced members in here...there are many gold nuggets laying around, one just has to pick them up.
Having a feeling of making a product far superior to others, ain't the right way to learn...your arrogance will block the positive input. (no offence to you and not meant as an insult).
That's right. But that's life. Some have more reputation than you (and me). Why? Because they are long time members and helped with their numerous posts homedistilling to a higher level. But not because they deserve it and you not, they get other answers, it's because we read different things between the lines.Hillbilly Popstar wrote:I guarantee if a different member had made a similar comment it wouldn't have found such critical responses.
In an oven? Do you have a specific duration at 380? Or do you think, a half hour more or less is all the same?HDNB wrote:consistantly. 380 is my magic temperature. 400 is too hot and gets acrid. 350 and below is woody.
Sounds like an admittion to folly.der wo wrote:That's right. But that's life. Some have more reputation than you (and me). Why? Because they are long time members and helped with their numerous posts homedistilling to a higher level. But not because they deserve it and you not, they get other answers, it's because we read different things between the lines.Hillbilly Popstar wrote:I guarantee if a different member had made a similar comment it wouldn't have found such critical responses.
And I think we all do the same. If we read something new, unexpected or incomplete (your "it's easy..." was incomplete imo) here, we also take into account, who writes it. Also because there are so many posts here every day, we don't decide right always. For example the discussion about marbles for packing. Of course noone would have believed rads success, if he was a new member.
We are reading here and have to decide, what could be right and what not. This behaviour is not bug-free, but the best we can do with our limited time and energy.
- Don't worry, you don't have a low value here. But anyway, your value on the forum is no real value. It does not define your value in real world.Hillbilly Popstar wrote: Sounds like an admittion to folly.
But such is life. Nobody is perfect.
Guess I just can't win.
3/4-1" thick (stave thickness) kinda wood, soaked for couple hours to rinse them, 1.5hours at 380. then medium to heavy char, then into the likker.der wo wrote:In an oven? Do you have a specific duration at 380? Or do you think, a half hour more or less is all the same?HDNB wrote:consistantly. 380 is my magic temperature. 400 is too hot and gets acrid. 350 and below is woody.
