back off topic: It helps not to drink much. You just need a bank of four fermenters of UJSM to try and keep up with for a few months. then you walk into the shed one day, realise what you've made, and just start laughing, maniacally. I imagine olddog here gets that a lot, looking at what he builds (see what I did there? off topic and back on again without sounding forced). I wish I was as legendry as olddog.
def: "A periscope is an instrument for observation from a concealed position" http://en.wikipedia.org/wiki/Periscope" onclick="window.open(this.href);return false;" rel="nofollow
Well here is the finished item, all clean and ready to go, I only have to fit the lenses in the sight glasses, then a vinegar run to clean out all of the build crap. then I can put a wash through and see what it will produce.
LWTCS wrote:that thing is clean. Did you put the final buff on by hand?
No not by hand, I have a buffing wheel on my bench grinder, makes your arms ache though with the wait of the thing.
LWTCS wrote:Really nice turn out. Spray it yet?
Yes I gave it a coat of clear laquer, I do this to allof my stills, they just need a wipe down after stilling to keep looking clean, and it stope oxidisation.
rad14701 wrote: I sure hope it works every bit as great as it looks...
All I can say is "What an incredible piece of art." I've always been fascinated by sight glasses, I always wonder what is going on inside.
Thanks for sharing,
myerfire
Time for the cleaning run. I had a batch of UJSSM ready to distill, and did not want to use the new column as it had not been cleaned after the build. I decided to use the Frankenstill, and after completing the run down to 40ABV and using some backset for the next batch, I removed the still from the column and added 6litres of vinegar and a litre of heads and tails from a previous run, I thought this would be a good mix to clean the new column.
I mounted the new column onto the boiler, attached my leibig and fired up the boiler again,it took a little while to heat up the new column and apart from a small leak from one of the sight glass mounts all was well. I had not attached the cooling lines to the dephlagmater as this was only intended as a cleaning run, the output ABV on the parrot was 65ABV and remained there long enough for me to take 2 litres. I am pretty happy with that considering what I was using for a wash.
I can't wait for another wash to finish, so I can connect the dephlagmater and see what sort of result I get from a proper wash, and running the column as it was intended.
The plates are a tight fit, and the upward pressure of the vapour holds the liquid on the plate, running this type of still too slow will cause the liquid to colapse the plate, so keeping the still with sufficient steam to hold the plate structure is essential.
Thats damn sweet Mike. I'm kicking myself in the ass for never buying a welder and setting up a propper workshop allthough I see it happening in the future.
Yeah Larry I have a torch but I have many good ideas in my twisted head and I always need a welder for somthing, and my small work place just isn't cuttin it.
pumpman wrote:and my small work place just isn't cuttin it.
My workshop is only 10' by 8', and has to store my wife's gardening stuff, my tools, and my distilling equipment.
When I take any pics of my gear, I am standing in the doorway.
I tried to upload a pic of my work place from my new cam but it sayes the file is invalid. Anyway I turned my garage into a bedroom when we had my baby girl so all I have to work with is a table about 4' by 5'.
