Why keep feints from a reflux column still?
Screech
Post by Screech »
Why keep the head and tails ?
I can understand collecting the heads and tails from a pot still and then puting them into a column still to get out the ethanol from them.
I dont have a pot still.
I only use a column reflux still with water and heat management.
So how am I benefiting from collecting the feints from my reflux column to just redo them again in the future?:econfused:
olddog
Re: Why keep feints from reflux column still?
Post by olddog »
They still contain an amount of alcohol if only a small amount, which can be retrieved later by re-distilling with your next run
big worm
Post by big worm »
that is a good question. i think you still have some good stuff in there because your never going to remove only heads or tails in feints there will be some good stuff mixed with them...as much as a pot stiller woud have...no no even close but enuff to save and give a good squeeze later. imho
GOT BAIT?
small children left unatended will be sold as bait
HookLine
Re: Why keep feints from a reflux column still?
Post by HookLine »
I throw the fores and heads from a reflux run into the container for holding sterilising/cleaning/firestarting/weed and ant killing spirits. It is my home made methylated spirit.
Tails I ditch. By the time you have extracted the ethanol, they ain't much left in those stinky stinky tails. Much easier and more productive to do a new ferment then re-run reflux tails.
Such a thing as diminishing returns here.
Be safe.
Be discreet.
And have fun.
I rarely chase after much tails with my reflux still either... Just not worth the effort...
airhill
Post by airhill »
Just checked the heads and tails jars from the last run. Heads 93.5% tails 55% (and ran into tails far longer than I normally do).
I would suspect the heads contain considerable ethanol as the other things coming out with them cause flavours and smells detectable by humans in ppt or even ppm. I toss 70-80ml fores from a 20l wash so I rerun heads and usually tails.
Boozehound
Post by Boozehound »
The sterilising ability of foreshots I find useful when cleaning glass stuff like bottles for wine. It saves having to use chemicals and thus saves a few pennies.
