Should I add some more sugar?
proudmary
Post by proudmary »
Guys... and gals..
The other night I started my first wash ever... A batch of sugar wash, I followed Wineo's Plain 'Ol recipe except that I didn't have epsom salt. With that exception, I followed everything exactly.
I added the yeast at 91 degrees.
Measured the SG and it was 1.059, low but I attributed that to the temperature. Using the SG calulator on the main site it calculated it out to 1.064.
So two days later I check it again, temperature is 70 degrees. SG reading is 1.040.
I have am keeping it sealed with an airlock.. Frist day lots of bubbles, second it just slowed down a bit to a couple every 3 - 5 seconds...
Am I on track here or should I think about adding some more sugar?
What benefit does the epsom salt provide? How does it effect the sg?
Thanks for your help..
Dnderhead
Re: Should I add some more sugar?
Post by Dnderhead »
you must have, about 1.5 Lb sugar to the gal. witch will give you 10% not bad, could add a bit more sugar, but it will just take longer to work off.
Epsom's salt adds magnesium , witch you mite already have in your water.
Id say just let it go the way it is.
Dnderhead wrote:Id say just let it go the way it is.
+1
Try not to worry so much about pushing your ferments to a high ABV. Especially if your pot stilling.
Stay at or below 14% IMO.
Less yeild but a cleaner likker with the lower ABV
The one thing that might help most would be raising the temperature to 75F - 80F... A few degrees makes a big difference to yeast...
Braz
Post by Braz »
I agree with Rad. Mine really slows down when the temp drops to 70 or less. I stuck a light bulb under the fermenter to keep the temp in the mid 70's at night when we turn the thermostat down. I also think 95 is a little hot for pitching the yeast. I know Wino's initial recipe post says that but later in the thread it seems to be revised downward - like 80-85.
I thought my WPOSW was stuck too but it finished out OK, though not real high ABV. Here's my thread about it, which may give you some hints, or solace. http://homedistiller.org/forum/viewtopi ... 15&t=13843
Understand, I'm a rank amateur at this too so anything I say may be complete nonsense. But I'm trying.
Braz
Braz
proudmary
Post by proudmary »
Thank you, I appreciate everyone's feedback. I try to maintain the temperature in that room by keeping the heater vent open and door closed. It's a small room 6'x8', I have a thermometer in there and reads anywhere from 72-76. If I add an additional heater, light bulb, etc.. how hot it too hot? What temperature do I want to stay below, 80?
Thanks again!
Dnderhead
Post by Dnderhead »
put it to bed. it will warm up.
