How hot is too hot?
SMOKEU
How hot is too hot?
Post by SMOKEU »
What temperature range should I keep my Still Spirits super reflux still at to avoid getting bad alcohols?
ScottishBoy
Re: How hot is too hot?
Post by ScottishBoy »
...room temperature...;)
( Im kidding, Im kidding!!!)
Try this write up by our kiwistiller..
http://homedistiller.org/forum/viewtopi ... iwistiller
He mentions a couple of ideas and cites some good references for the unit and includes ideas to modify it to perform better.
The search function is pretty good too.
ScottishBoy
HD Survival in a Nutshell...
ScottishBoy wrote:...room temperature...
I liked it.
olddog
Post by olddog »
If you have to ask this question, it's obvious a lot of reading is required.
ScottishBoy
Seriously though....Its easy to make fun, but there is a crap load of experience here and the only way you can get to it is to read. I promise you, it will be worth it. There are some great characters here and they will help you understand the little nuances of your still. In time, you will want to build your own...THAT'S when the fun begins!
Your first still is like your first car. You may want to add some things or wish it did things differently, but when you get to your second one...Well, you know what you want.
It's all part of the process...enjoy!
SB
ScottishBoy
SMOKEU
Post by SMOKEU »
I did use the search function and it didn't show me what I wanted to know.
SMOKEU wrote:What temperature range should I keep my Still Spirits super reflux still at to avoid getting bad alcohols?
Did you get this document with your still...???
Don't do a run until you are well aware of what you are doing... Reflux still theory doesn't vary much between types... CM, LM, and VM, all have similar behavior within each type...
SMOKEU
Post by SMOKEU »
I'll keep it under 92°C then.
