Hi guys first of all thank you for the replies.
Smokeu, they sell them at brewcraft etc, SS extension tower I believe they are called, they are full of ceramic saddles and made a very big difference to my ability to regulate temps and the quality of the distilate.
OldDog The coolant will flow through the spout condenser then into the top of the column coil condenser.
rad14701 the concept of distilation is not complex (evaporation and condensation of a substance at which temperature it turns to vapor), the complexety arises from what you aim to achieve from the distilation, in this case I am aiming for the highest possible quality of the distilate, since I will only be using for nutural spirits. I have read designs and if you have to you can see this is basically a fractional stil without heat source temperature management.
What I aim to achieve with this design with the double condensing is to reflux volatiles below say 76c (back into the packing) and allow the vapor to pass though the coil and to be condensed by the spout which in theory should be fine since the ethanol can still pass by the internal coil, i believe fractional stills also use this tried and true design.
rad14701 When you say the design is inefficient in what way? as efficiency can mean many things depending on what you are aiming to achieve?
"you should not be attempting to regulate the vapor temperature at the take off branch using a condenser below the branch... That's the surest way to turn yourself into a still jockey for the entirety of the run... This is the WHY behind the poor design."
I do not believe this to be the case? since the cooler water will be flowing into the spout, the water will already be slightly warmer by the time it reaches to column condenser coil and since it is being regulated there once the boil equalises the only temperature rise should be caused as the ethanol content of the wash becomes lower, as long as the spout is long enough and cool enough that should be all that matters.
The questions I have on still design are not from lack of knowlege more so recommendations on lengths, sizes of materials from people who are more experienced than myself, I dont believe any amount of research can compare to someone who has manufactured first hand for years and put theory into practice and come up with their own designs.
I would also appreciate you be a bit more easy on me this time with your reply.
Below is a diagram for a fractional stil with heat source temperature management at the heating point, I believe a fractional stil can also have the temperature management above the packing by using a coil which I have in my plans.
![Image](http://www.chemguide.co.uk/physical/phaseeqia/apparatus.gif)
Fractionating columns help to separate the mixture by allowing the mixed vapors to cool, condense, and vaporize again in accordance with Raoult's law. With each condensation-vaporization cycle, the vapors are enriched in a certain component.
(Exactly what I am aiming to do)
