Is this ok?
Is this ok?
Just wondering if this still would be any good? http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT" onclick="window.open(this.href);return false;" rel="nofollow
I am looking at doing neutral spirits for the moment but may want to try my hand at flavoured later on.
I already have a 30L boiler with dual elements (1800w & 1200w) and heat control (30 - 110 degrees celcius), just need to find a decent still now...
The Pope - Beer Bishop Brewery
Re: Is this ok?
That looks like a Bokabob to me, why not build one yourself, there is plenty of info on the forum.
OD
OD
Re: Is this ok?
I believe that the debil part of the still is the wide wounded coil.
I think that it'll have problems to knock down all vapor.
Add image:
Add image:
Re: Is this ok?
I hate to be the one to have to break it to you, but controlling heat input based on temperature in the boiler doesn't actually work very well. the wash will boil at a temperature set by the mixtures of liquids in the boiler, not at what you set it to would make our lives a lot easier if it did work, but that's physics for you I guessevil_spirits wrote:I already have a 30L boiler with dual elements (1800w & 1200w) and heat control (30 - 110 degrees celcius), just need to find a decent still now...
I'd agree with the others in that you'd be better off making a still if you can.
Three sheets to the wind!
My stuff
My stuff
Re: Is this ok?
+1 OD, looks like a Bokakob Cup or slant plate. Not sure about that coil though, joes right, could have a problem knocking down the vapour.olddog wrote:That looks like a Bokabob to me, why not build one yourself, there is plenty of info on the forum.
OD
I'd rather build my own, theres nothing better than drinking your own hooch from your own still. Now where's that bottle...
♦♦ Samohon ♦♦
Re: Is this ok?
kiwistiller wrote:I hate to be the one to have to break it to you, but controlling heat input based on temperature in the boiler doesn't actually work very well. the wash will boil at a temperature set by the mixtures of liquids in the boiler, not at what you set it to would make our lives a lot easier if it did work, but that's physics for you I guessevil_spirits wrote:I already have a 30L boiler with dual elements (1800w & 1200w) and heat control (30 - 110 degrees celcius), just need to find a decent still now...
And if the temperature is controlled by a thermostat, which it almost certainly will be, that is bad too. You need a steady application of power/ heat, not the on-and-then-off operation of a thermostat. Especially with a reflux still; the reflux action stops when the power stops and has to take time to start again. Time that the thermostat does not give it because it cuts off the power again......
Re: Is this ok?
+2 CONDENSER WILL NOT WORK i FEEL SURE OF IT. you can build you own much cheaper.Samohon wrote:+1 OD, looks like a Bokakob Cup or slant plate. Not sure about that coil though, joes right, could have a problem knocking down the vapour.olddog wrote:That looks like a Bokabob to me, why not build one yourself, there is plenty of info on the forum.
OD
KS
Re: Is this ok?
That coil is weak. I think half the fun of learning to still is making the still itself and makin it to your liking.
That said...I think you could do better.
ScottishBoy
HD Survival in a Nutshell...
Re: Is this ok?
Thanks guys, after reading the forum all night I see what you are saying.
I have decided to build the "Bokabob cup" still as it looks like a simple design that I can throw together myself.
And I will be using a keg boiler for this too as I have a 60L fermenter so this way I could do a 40L wash & spirit runs...
Re: Is this ok?
When looking at temperature controls, you should think of it this way, its like driving a car. you get up to speed (temp) then you partially apply the throttle, to maintain the speed (temp) you like. you dont floor it/let off/floor it/let off. It wouldnt be too smooth if you drove like that now would it? Your still dont like it either.
-Control Freak-
AKA MulekickerHDbrownNose
Re: Is this ok?
That's how my wife drives.
Re: Is this ok?
My wife's motto is
"If you don't like the way I drive
Stay off the footpath"
Build it, don't buy it
Re: Is this ok?
I don't think that column has slant plates like the Bokakob... I think it has a tube with the top half removed inserted into the column so it catches the reflux until it overflows, like the one below... It's called The Ultra Pure Still... There are more detailed pictures somewhere here in the forums...
Re: Is this ok?
I went and got the materials to build my own today and it is coming along nicely.
Thanks again guys, it was a way better option for me as it has cost me ALOT less then if I was to purchase one retail and it looks to be a pretty easy project so far...
Re: Is this ok?
Hmm. Not too happy with that condenser either. Could be improved, IMHO.
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
Re: Is this ok?
Ruined the coil & wasted $30 odd dollars.
Anyone want to make me a double coil to suit a 2" condensor pipe?
Re: Is this ok?
Where do you live? I just made this one the other day.evil_spirits wrote:Ruined the coil & wasted $30 odd dollars.
Re: Is this ok?
I bought one of these, was hoping to run it with the thermostat set hotter, if it started cycling I could bypass the thermostat and set the two elements up with two switches. Both elements for a quick heat up then just run with one of the elements for the run.evil_spirits wrote:
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWNX:IT" onclick="window.open(this.href);return false;" rel="nofollow
Re: Is this ok?
I am in St Marys NSW. Australia.mozzie26 wrote: Where do you live? I just made this one the other day.
If intereste in selling one please let me know ASAP...
Yep that is the one. Same boiler as what I have been using for brewing beer.mozzie26 wrote: I bought one of these, was hoping to run it with the thermostat set hotter, if it started cycling I could bypass the thermostat and set the two elements up with two switches. Both elements for a quick heat up then just run with one of the elements for the run.
I was going to try & use it as a still boiler but decided to go with a keg & propane now for better heat control...
Re: Is this ok?
I'm in the Sunshine Coast. Qld , I could make you one for the cost of the copper plus postage, if your happy with the look of my work . The 1/4" copper tubing cost's $9.20/m here. I have made mine to have the tails come out the side of the 2" tube but have been thinking of changing them to come out the top cap.
Re: Is this ok?
That would be great mate if you wouldn't mind.
I would need the tails out the top cap though as i have already drilled the holes for them.
I will shoot you a PM anyway and we can work out the details...Cheers...
