My Rig
My Rig
Bayou Ethanol
Ethanol Fuel Producer
AFP-LA-15027
http://www.BayouEthanol.com" onclick="window.open(this.href);return false;" rel="nofollow
AFP-LA-15027
Re: My Rig
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
nice looking wash tank, i want one of those.....
but i think you should get rid of the plastic product tube.....
and maybe move that can of gas / fuel further away
what sort of % you getting
![Smile :)](./images/smilies/icon_smile.gif)
Re: My Rig
Nice looking rig for a CM column, Bayou-Ruler... You really need to reduce the size of those images, however, or one of the mod's will either do it for you or remove them...
Re: My Rig
the old style CM as it should be done there. well done. After you sort out your pictures, I might link your post here to the overview of reflux designs, it's a good example of a simple improvement on the old through column reflux design.
Three sheets to the wind!
My stuff
My stuff
Re: My Rig
Nice compact Rig Bayou-Ruler... How's she runnin.... I'd probably lose the plastic tube on the take-off and replace it stainless steel or copper. Apart from that, she looks real good man...
♦♦ Samohon ♦♦
Re: My Rig
is that a rubber bung in the top where your thermometer is at? if so you need to get rid of that. I would also get rid of the rubber hose where your product comes out.
other than that very nice.
Re: My Rig
maheel wrote:nice looking wash tank, i want one of those.....
and maybe move that can of gas / fuel further away![]()
The tank is available here: http://www.brewhaus.com/" onclick="window.open(this.href);return false;" rel="nofollow
The fuel can is actually farther away than it appears in the photo.
According to my calculations I'm getting 90%abv
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Yes it is a Pure Tan Gum Rubber Bung & Chemical Tolerant Tubing.Kentucky shinner wrote:is that a rubber bung in the top where your thermometer is at? if so you need to get rid of that. I would also get rid of the rubber hose where your product comes out.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
I will have to look into replacing the tubing and the bung at the top. She is runnin pretty good far as I can tell. I have put about 6, 23 liter sugar washes through it. stripping run takes about 2 hours and spirit run abut 6 or 7 hours.Samohon wrote:Nice compact Rig Bayou-Ruler... How's she runnin.... I'd probably lose the plastic tube on the take-off and replace it stainless steel or copper. Apart from that, she looks real good man...
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
rad14701 wrote:Nice looking rig for a CM column, Bayou-Ruler... You really need to reduce the size of those images, however, or one of the mod's will either do it for you or remove them...
I re-sized them. Hope they are better now. I have a large monitor set at high resolution so large images aren't so large on my end.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
look good to me. in future, if you upload them as an attachment, they'll auto-thumbnail.
My stuff
My stuff
Re: My Rig
kiwistiller wrote:look good to me. in future, if you upload them as an attachment, they'll auto-thumbnail.
Thanks, I will have to do that in the future.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
My Rig- More Pictures
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
very nice. I'm interested - do you ever get trouble from the coolant warming, and then changing how much you're refluxing?
My stuff
My stuff
Re: My Rig
kiwistiller wrote:very nice. I'm interested - do you ever get trouble from the coolant warming, and then changing how much you're refluxing?
That is a 152 quart (143 Liter) ice chest so there is a fair volume of water. That bottle floating there in the picture is a 3 liter cola bottle. I have several of them filled with water that i keep frozen. I will feel the outer tube on the condenser, or the return water. When it begins to warm up I will add the frozen 3 liter bottles one at a time til it cools down to where i want it. The frozen bottles also come in handy for cooling down hot mash.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
I took your advice and got rid of the tubing on the take off. I replaced it with a copper compression fitting and copper tubing. Next run I will take a picture of it. Next item on the agenda is to eliminate the rubber bung.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Awesome rig Bayou Ruler. Hey I'm from Louisiana too! ![Smile :)](./images/smilies/icon_smile.gif)
Re: My Rig
RebelRick wrote:Awesome rig Bayou Ruler. Hey I'm from Louisiana too!
Thanks Rick
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig- In POT Mode
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Bayou-Ruler~
I have the same set-up as you, just a little curious as to what you think about it?
For the regulars~
Why the need to eliminate the bung at the top? And what would make a sufficient replacement?
For the regulars~
Re: My Rig
Fiendish wrote:Bayou-Ruler~
For the regulars~
Fiendish, I love it! I have returned my upper column to Brewhaus and I'm having them add a 2'' Ferrule to the top where the Bung usually gos. I'm going to eliminate the Bung by using some stainless tri-clamp fitting and compression fittings to hold the temp probe.
SEE PIC:
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Bayou~
Any updates on the new top? Just itching see how it turned out.
Re: My Rig
me 2 as i have the same bung on the way from milehidistilling. i guess this goes under the copper, stainless only rule?
[><]WHISKEY DRIVEN RIVERRAT[><]
Re: My Rig
Bayou-ruler, nice looking rig and good job of getting rid of the plastics. I hate to be the one to keep finding issues with it...but, the brass coupling that you used to connect the copper collection tube is also undesireable unless you used the de-leading process here on HD. MM
Re: My Rig
Mud Mechanik wrote:Bayou-ruler, nice looking rig and good job of getting rid of the plastics. I hate to be the one to keep finding issues with it...but, the brass coupling that you used to connect the copper collection tube is also undesireable unless you used the de-leading process here on HD. MM
Thanks for the compliment.
Actually I have been wondering when some one was going ask about the brass fitting and yes it has been through the vinegar and peroxide de-leading procedure.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Fiendish wrote:Bayou~
My column should arrive back to me today on the UPS truck. Brewhaus did an outstanding job on the turn around time. They did the work and shipped it back to me the same day they received it. The other parts that I have ordered are scheduled to arrive on Friday.
I purchased them here: http://www.thevintnervault.com/index.ph ... gory_id=72
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Looking good brother
KS
KS
Re: My Rig
Thank You, Kentucky shinnerKentucky shinner wrote:Looking good brother
KS
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
Re: My Rig
Here is a picture of the ferrule I had added to the top of the column:
When the rest of my parts arrive I will post more pictures.
Bayou Ethanol
AFP-LA-15027
AFP-LA-15027
