immerson heaters
philippa
immerson heaters
Post by philippa »
i am just starting out with a new reflux still. it is heated with a 1500 watt immerson heater plugged into a 120 volt wall socket. i cant seem to keep the tempeture high enough when i add in the cold water in to the bottom of the reflux. is it because my heater is too low wattage.
thanks for any suggestions!
philippa
Dnderhead
Re: immerson heaters
Post by Dnderhead »
sounds like you have a CM and the old stile at that. if so disregard the bottom tube. even better remove it and place in the top with the other one.
or better change it to something else.
A picture of your rig would definitely help us help you...
