This is a bit late I know , but I just read your post , and looked at your setup. Keep in mind that I am at best a novice distiller , and this is just my humble opinion.
It seems that you have quite a bit of tubing for the gas to pass thru in order to get to your airlock.
The small amount of pressure generated by the fermentation in the later stages , may make it difficult , if not impossible for the gases to make the trip to the airlock---- path of least resistance and all.
You may be better suited to cut you tubing , and form 6 small bubblers(airlocks) than to try to use one central one.
My fermenters are identical to yours with the exception of the airlocks.
I used small prescription pill bottles( no inferences please) - the type with the snap-on lid.
Each airlock consisted of the bottle with a hole just the right size to allow a tight fit of the hose without air leaks to penetrate the lid.
In addition to that hole , I made a smaller hole , perhaps 1 mm in diameter to allow the offgases to escape the bottle.
As long as your hose remains submerged in the water you have a working vapor lock.
The length of tubing allowed for the medicine bottle to rest at the edge of the fermenter in a vertical position , so as to not allow the water to spill.
Works great for me , and I have no trouble with the gases becoming backed up in the fermenter and potentially doing harm to my mash.
Again , I am a humble novice, and this is just my opinion, and what works for me. But , I will say if you use my rigs, you will have alot of extra tubing left over to go toward making additional fermenters
Lumberped
