What is a bushing reducer?
Rum Bum
Post by Rum Bum »
What's the difference between a bushing, and a bushing reducer? And a bushing reducer and a reducer?
Plumping terminology for the nube just doesn't exist on google.
RB
Prairiepiss
Re: What is a bushing reducer?
Post by Prairiepiss »
A bushing reducer fits inside a fitting and the pipe fits inside of it.
Look on this link. Scroll down and look at the bushing. You will see it looks like a slug. You place this slug inside say a 90 then you can place the smaller pipe inside it.
http://www.globalindustrial.com/c/plumb ... ngs/copper" onclick="window.open(this.href);return false;" rel="nofollow
Generally bushings and bushing reducers are referring to the same thing.
Google search copper bushing reducer.
ozone39
Post by ozone39 »
A bushing changes the OD of the pipe with minimal fitting allowance, Fitting allowance is how much room or distance it uses up...A Fitting reducer is a two step fittings that "fits" in to a fitting and couples around a pipe...A copper bushing reducer can also referred to as an insert reducer.
F x C reducer, fitting by coupling reducer.....(inside pipe diameter x out side pipe diameter)
fitting reducer.jpg (5.76 KiB) Viewed 2527 times
Insert reducer or also know as a copper flush bushing
insert reducer.jpg (5.9 KiB) Viewed 2527 times
Rum Bum
Post by Rum Bum »
Thanks guys, I'm trying to wrap my head around all the terms. I have no background in copper pipping what-so-ever.
RB
