UJSM cloudy?
Johnben
UJSM cloudy?
Post by Johnben »
Sorry for the newbie question, but i am doing a 10gal run of UJSM and the first 7 quart jars were perfect, at the 8+ they get noticeably cloudy this is the first time i have seen this, is it a problem? the jars i am using are new and i don't think i am running too hot.
Thanks in advance for the advice
Re: UJSM cloudy?
That would be tails... If early on it would be puking...
Johnben
Re: UJSM cloudy?
Post by Johnben »
thanks for the quick response, i figured it was, i had never seen my tails start so eardly, these jars are 90proof (probally should of added that info eardlier)
Johnben
Re: UJSM cloudy?
Post by Johnben »
I have to say im not sure that it is the feints, i turned down the still a little and it seems to of cleared up :shock: , i also looked at my other feints i have around and they dont look the same as the stuff i was getting. im pretty sure it was puking now that it was mentioned.
CuWhistle
Re: UJSM cloudy?
Post by CuWhistle »
If you were to assume your wash was 8%;
10 gal @ 8% = 3.2 Qts @ 100%
= 6.4 Qts @ 50%
You've taken 7 Quarts and clouded at #8.
Which jars are 90 proof? Your jars should be higher to start (say 120 - 130) and getting progressively lower. With UJ usually my tails don't start to really show through until about 80 proof or lower.
