4" Lm thingamebob
googe
4" Lm thingamebob
Post by googe »
What's everyone think of this plan?, I'm going to start it in a week or so if there's no big faults anyone can see?. Thanks for any feedback.
"Homer J Simpson"
jholmz
Re: 4" Lm thingamebob
Post by jholmz »
no plan visible googe
googe
Post by googe »
Wtf? Lol sorry.
"Homer J Simpson"
googe
Post by googe »
Thanks rc, I was going to do what you did at one stage but thought stuff it I'm to lazy lol. The deflag is over done so should have plenty of guts to keep up.
"Homer J Simpson"
googe
Post by googe »
Some.progress finally . Did a different down comer to.try help the falling distillate be centred. Going to be scoria packed.
"Homer J Simpson"
acfixer69
Post by acfixer69 »
That downcomer doesn't have enough trap to hold back the vapor :(
AC
acfixer69 wrote:That downcomer doesn't have enough trap to hold back the vapor :(
AC
+1
googe
Post by googe »
Hmmm I'm seeing a trend here, was wondering that myself. Will put the plate in my bubbler and do some testing, only way to find out.
"Homer J Simpson"
acfixer69
Post by acfixer69 »
Wasn't being a naysayer just bin their don't work, figgertng to say something before you burned it in. Much harder to fix after then before:D
AC
googe
Post by googe »
All good, just wasn't aware you had actually tried one, was it exactly the same?. I appreciate the feed back .
"Homer J Simpson"
acfixer69
Post by acfixer69 »
Not exactly the same at all. Looking at the tip off on the horizontal section there is a liquid level lower then the bend in the elbow IE no trap and when the vapor is screaming through there will not work. Just letting a flag out before the solder hits the copper. Not trying to be an engineer but looking at your liquid level on the plate the trap is going to be much deeper. Just advise its your show :thumbup:
AC
googe
Post by googe »
Thanks for the input mate, I'm not gunna test that trap now, waist of gas and time, just gunna put 2x 90's for the trap.
"Homer J Simpson"
That J-trap would have worked if you had soldered a small piece of copper into a slot so that vapor couldn't travel over the liquid into the down tube... A vapor dam extending down ~1/2 - 2/3 would do the trick... It would still be less efficient when the plates are first filling but would eventually operate properly...
googe
Post by googe »
Cheers rad, good idea, would fix it!. I'll just stick with a standard j trap though. I waist to much time thinking up new shit when tried and true things work fine.
"Homer J Simpson"
googe
Post by googe »
Did the needle valve and mini liebig today.
"Homer J Simpson"
googe
Post by googe »
Bubble plate, deflag and coolent input/out done.
"Homer J Simpson"
DrunkASAskunk
Post by DrunkASAskunk »
nice looking work mate :thumbup:
Does look nice and tidy.
googe
Post by googe »
Thanks fellas :thumbup:
"Homer J Simpson"
googe
Post by googe »
Would the best place for the thermo be under the bubble plate?. Thanks.
"Homer J Simpson"
googe
Post by googe »
Some.more.progress.
"Homer J Simpson"
googe
Post by googe »
Sacrificial run done, wasn't real happy with how it ran, plate kept collapsing, will hopefully do some more testing this weekend.
"Homer J Simpson"
googe
Post by googe »
Doing a first complete run, 44" packed with scoria about 20mm diameter pieces. Interesting to see how it runs with the large hole in the top, lots of pulsating!, got a straight birdwatchers going. it's running a little fast in the vid, has stabilized now and refluxing for a while, fingers crossed. Sounds like a tractor :lol:
"Homer J Simpson"
googe
Post by googe »
Seemed to run well, single run at 3.3lph at 90%. ABV was lower than I was hoping but it was very clean so far, will let it air for a day or two and do some tasting. If I can get a nice neutral type from.a.single run my still building is finished :lol:
"Homer J Simpson"
googe
Post by googe »
After resting a week, had a taste test tonight, the missus is an aromatherapist and has a nose like a blood hound, gave her a smell and she said she could smell nothing!. Taste is pretty much nothing too. So, I've achieved what I wanted, a neutral to suit me in a single run :D . Next mission is a rum through it with either reduced packing or column height disabling. then I'll have all I need, a still for all my needs with minimal fuss.
"Homer J Simpson"
bellybuster
Post by bellybuster »
Heya Googe, do I see that right? Your def is a single pipe path? Is it able to knock down everything?
googe
Post by googe »
Yeah mate, single tube. It's at it's limit at a bit over 3lph, I'll stick a scrubber in it next run and see what happens. Wish I'd made the deflag just a little longer cause I reckon a could get much more than 3 lph.
"Homer J Simpson"
googe
Post by googe »
I see 4" packed columns discussed and arguments about its to big re packing. Use the right packing and no issues.
"Homer J Simpson"
Bolverk
Post by Bolverk »
I came across mention of the amphoria society pda1/2 and ever since I've been considering doing a 4" LM. Seems like a pretty versatile rig
googe
Post by googe »
Bump....
"Homer J Simpson"
