How to run Auber PID in manual
If it plugs in, post it here.
muddog
Post by muddog »
Here is how to program Auber Pid to run in auto or manual with a push of a button.
Push set button until it goes to menu mode, release button, now press and release to go thru menu.
Go to auto setting, in first pic.
Default setting is 2 , auto only, set to 0, auto or manual, using arrow
After a few seconds it will exit menu mode.
To go to manual press A-M button(2nd from left ), the A-M light will come on. To go back to auto push A-M button again.
You still need to adjust power output. Press, release set button, you will now see an A followed by a number, on the bottom display (2nd pic), this is the output value.
Adjust output values with the arrows. Output can be adjusted from 0 to100. You can easily adjust output values anytime in this mode. Muddog
Simple pot still for simple likker
Moonshine and oysters, the breakfast of champions
"Don't turn on the lights cause I don't wanna see. Mama told me not to come" Randy Newman
rolsen99
Re: How to run Auber PID in manual
Post by rolsen99 »
Hey mud, you look versed on these units, are you able to run in manual mode without the thermocouple hooked up?
sambedded
Post by sambedded »
PID requires thermoprobe even for manual mode. But you can trick it using 100 Ohm resistor instead of probe.
muddog
Post by muddog »
sambedded wrote:PID requires thermoprobe even for manual mode. But you can trick it using 100 Ohm resistor instead of probe.
That is not correct. When you run in manual , you are setting to percentage of time the PID is going to power the element, i.e manual setting of 60 will power element
60% of time and power off 40% of time , the thermocoupler is bypassed. Muddog
sambedded
Post by sambedded »
Have you ever tried to run it in manual mode when thermosensor is disconnected?
Syl -2326 just doesn't allow you to do "setting to percentage of time" without sensor.
muddog
Post by muddog »
Yes , I run in manual. I leave it the tc connected. It bypasses the tc.
I use this: http://www.auberins.com/index.php?main_ ... ducts_id=3" onclick="window.open(this.href);return false;" rel="nofollow
i
sambedded
Post by sambedded »
Now power off your panel, disconnect a thermocople and try to run PID imanual mode again.
muddog
Post by muddog »
You are right . I didn't understand what you were saying.
You do have to have a TC connected or a resistor connected for the PID to function correctly. Even though it serves no purpose other than a temp indicator. It is bypassed in manual mode.
rolsen99
Post by rolsen99 »
I am electrically challenged, how would I hook up the resister? Right now I have to pull out my brew kettle to run PID in manual mode with still, would be great with the resister trick! I have the "fancy" cable and connecter from auberins.
sambedded
Post by sambedded »
Do you want to hook up resister permanently (directly to PID) or to have an ability to plug it instead of thermoprobe?
rolsen99
Post by rolsen99 »
sambedded wrote:Do you want to hook up resister permanently (directly to PID) or to have an ability to plug it instead of thermoprobe?
I just want the ability to plug it.
muddog
Post by muddog »
I did some searches and couldn't come up with anything on bypassing TC with a resistor.
If some body knows how to do this, I would appreciate a post on it.
In the meantime, if your TC plugs into your control box, ( see pic) you can buy a cheapie TC from fleabay and use it instead of your boil pot TC. Muddog
sambedded
Post by sambedded »
Typical PT-100 thermoprobe looks like:
Just use a 100-150 Ohms resistor instead of Pt-100 element.
muddog
Post by muddog »
rolsen99 wrote:I am electrically challenged, how would I hook up the resister? Right now I have to pull out my brew kettle to run PID in manual mode with still, would be great with the resister trick! I have the "fancy" cable and connecter from auberins.
sambedded wrote:Typical PT-100 thermoprobe looks like:
So there you have it . Thank you sambedded.
Auber Pid also accepts K type coupler ,which uses 2 wires , can you use K Type setting and put resistor between those 2 wires instead?
It would be simpler that way. Muddog
rolsen99
Post by rolsen99 »
OK, I think I understand, thanks for the help.
muddog
Post by muddog »
According to Auber you can do this, instead of using TC or resistor.
From Auber:
Please set the SYL-2352 PID's SN = 0 and use a copper wire to short cut the terminal 4&5 (where it should be connected to the thermocouple). Then the controller will display ambient temperature.
Muddog
