though i knew something.
ihatemurphy
Post by ihatemurphy »
i finally got a still put together. brewed a batch of mash and i am now the proud father of 15 gallons of vinegar. anyone have any advice? is there a chance to continue to brew in the same location? and fermenter? I've been told that once i have vinegar i will forever get vinegar. any truth to that? thanks for any and all help.
Re: though i knew something.
Welcome to HD, we need more information what did you use as a mash/recipe?
ihatemurphy
it was 100% corn. 10 lbs self malted 20 lbs cracked corn. 15 gallons of water. turbo yeast.
Just find a recipe in the TnT section fer starters
NB01
Post by NB01 »
1. Throw the turbo away, seriously.
2. Read a hell of a lot more (links in my sig)
Well, between Scotch and nothin', I suppose I'd take Scotch. It's the nearest thing to good moonshine I can find.
- William Faulkner
The Forum Trilogy
The Rules We Live By
New To Distillation
The Parent Site
The More You Know
ihatemurphy wrote:it was 100% corn. 10 lbs self malted 20 lbs cracked corn. 15 gallons of water. turbo yeast.
Again, for the 1,000th time, never use turbo yeast with anything but sugar and water... With grains or cereals it will produce too much heat and impart off smells and flavors... Another possibility is the generation of too much heat which can either kill the yeast colony or cause the issues previously mentioned... Write this one off as a lesson learned and forget that turbo yeast even exists...
