Still on ebay.
brian41527
Still on ebay.
Post by brian41527 »
I saw this this still while searching on ebay, would it be worth bidding $125 on?? http://cgi.ebay.com/MOONSHINE-ETHANOL-S ... dZViewItem" onclick="window.open(this.href);return false;" rel="nofollow
MisterSteve124
Post by MisterSteve124 »
Well the still doesn't look that bad compared to others, but you could build something very similar yourself if you had any handyman skills for under half the price. Just buy a cheap pot at a store and attach some copper pipe and fittings and thats almost it. Unless you got money to burn I would read some stuff on this site and try making on yourself in a little bit.
junkyard dawg
Post by junkyard dawg »
I don't care for that.
There are lots of others here that run that kind of still tho...
not sure about the thumper... the boiler is the cheapest thing that could work. sealing the lid is a pain in the ass... If you really wanna make some shine, and want a reasonable return on your investment then I would go a different route. depends on your space and resources... You can do a lot better for the money...
arkansas
Post by arkansas »
http://i9.ebayimg.com/04/i/000/c9/65/7a7f_1.JPG" onclick="window.open(this.href);return false;" rel="nofollow
I wonder about this flange, this looks like galvized stuff, bad deal if it is, even if it is on top of the lid, it accepts the threads from the copper pipe, there will be some contact. It looks cool but, I have to wonder.
HookLine
Post by HookLine »
Hard to tell just from that photo. It could just as easily be stainless or aluminium.
Be safe.
Be discreet.
And have fun.
arkansas
Post by arkansas »
HookLine wrote:Hard to tell just from that photo. It could just as easily be stainless or aluminium.
I agree, just wonder I guess, looks kinda rough for stainless, but you are right, can't tell for sure what it is. :?:
Cruisaire
Post by Cruisaire »
Looks like zinc plate to my untrained eye. Oh and that pot looks identical to my latest cheapie SS pot I just got.
pintoshine
Post by pintoshine »
that is a still from http://www.stilldrinkin.com" onclick="window.open(this.href);return false;" rel="nofollow Several people have complained about non-delivery after payment and them not returning calls.
That is the model called the venom
HookLine
Post by HookLine »
Stainless can have a pretty rough finish, the smooth brushed or polished finish that a lot of stainless has is just to make it look good. The finish on my stainless keg connector looks very similar to that flange.
http://i152.photobucket.com/albums/s197 ... ection.jpg" onclick="window.open(this.href);return false;" rel="nofollow
Note the difference between the finish on the keg and column, and the finish on the fittings.
I sure hope that flange ain't zinc plated mild steel. :shock: :shock: :shock: That would be seriously irresponsible, especially seeing as that is a 'professionally made' still.
Be safe.
Be discreet.
And have fun.
Husker
Post by Husker »
This is the still drinkin "venom". Yes, I have also heard many people complain about not receiving a still from those folks after paying for it.
I would avoid that still if I were you.
H.
Cruisaire
Post by Cruisaire »
HookLine wrote:Stainless can have a pretty rough finish, the smooth brushed or polished finish that a lot of stainless has is just to make it look good. The finish on my stainless keg connector looks very similar to that flange.
I see what you mean. Yours just looks less "bright" and has the characteristic dull gray I see in unpolished stainless.
grainhopper
Post by grainhopper »
Pretty sure that is galvonized.
It has the same markings that a flange I have bought from Lowes, that I use on my boiler.
This is from the main page if this isnt the truth then I need to change my flange.
Galvanised Metals
Tarvus explains ...
Galvanised materials are not safe to use on the condenser side, but if it's part of the boiler or at the bottom end of the column, it should be fine (provided you don't boil so vigorously that your wash bubbles up through your column and into your collecting container. Toxic salts from metals can be dissolved in liquid, but remain behind when the liquid is vaporized (as in a reflux column).
For example, you could toss a handful of lead fishing sinkers into your boiler which could well leach toxic levels of lead into the wash. But once the vapor runs through the column, it's free of the lead salts and safe. If you used lead based solder (or galvanized parts) in your CONDENSER, that would be a different story. The hot liquid condensate could leach lead salts from soldered joints or zinc from the galvanized parts and you would wind up with contaminated product.
Read Please, Try it, Learn!
HookLine
Post by HookLine »
That is technically true, Grainhopper, but there are at least four problems with that:
1. Even the best still operator cannot gaurantee there will never be any boil over.
2. Galvanised finishes will corrode in the hostile environment within the boiler, exposing the raw metal underneath (usually mild steel), which will also corrode, possibly causing leaks.
3. Getting toxic metallic salts into the wash probably means that you cannot use the backset/dunder in subsequent ferments.
4. There will always be some klutz who doesn't get it and uses the wrong materials in the wrong place.
I reckon it is just a whole lot easier to completely avoid these materials, and stick to stainless or copper in the first place. The cost difference is not significant, especially over the lifetime of a still, and taking into account the safety/health issue.
Be safe.
Be discreet.
And have fun.
punkin
Post by punkin »
I use those flanges often. That is a galvanised flange, for what it's worth.
Say's in the ebay description that it's stainless (it's not), but it also says that the unit sold will come with a brass flange rather than that one, so i don't think it's worth getting too uptight about :?
goose eye
Post by goose eye »
looks like a ole base they put on platform they use to screw swivel on for speed bags. new some ole boys that use to box a long while back . use em bases for railins to.
so im tole
barrelcreator
Post by barrelcreator »
I just finsihed builind the "ministill". With a turkey fryer as the pot the whole thing cost me $90. If you are going to spend $100 buy or build the exact one you want. If this is the syle you want buy it. If not your price range will allow you to build the one you want. Just my 2 cents... :lol:
punkin
Post by punkin »
goose eye wrote:looks like a ole base they put on platform they use to screw swivel on for speed bags. new some ole boys that use to box a long while back . use em bases for railins to.
so im tole
It's a galvanised pipe flange, Goose.
You screw it too a piece of threaded 50mm (2") gal pipe, and you can bolt on other fittings for pumps, valves ect. You can get em in brass too. Maybe you could get em in stainless, but i've never seen em. :lol:
ChillinDistilln
Post by ChillinDistilln »
I was bidding on the same still... but lost and in retrospect I was lucky.
Several minutes later the seller sent me a second chance offer, but I declined.
I put in a bid on another still on Ebay and won it for the same price, but it looks like a much better product:
http://cgi.ebay.com/5-gal-TILT-REFLUX-M ... dZViewItem" onclick="window.open(this.href);return false;" rel="nofollow
I bought this one.. as long as I receive it I'll be happy.
I started with a "wok" still and then used a Kenmore distiller and was never unhappy... but wanted a bit more. I think this will fit the bill.
I couldn't have built this for the same price. Again.. as long as I receive it I'll be happy!
goose eye
Post by goose eye »
punkin look up speedbag swivel .
they screw the swivel to the base - you callin it flange - srewed to platform.
there moren one use for thangs i guess kinda like corn
so im tole
punkin
Post by punkin »
goose eye wrote:punkin look up speedbag swivel .
so im tole
Too true
grainhopper
HookLine wrote:That is technically true, Grainhopper, but there are at least four problems with that:
Well I made myself a makeshift flange that will be interchangable columns.
Here are some pictures.
I did this to stabilize it some.
HookLine
Post by HookLine »
Nice job.
Be safe.
Be discreet.
And have fun.
junkyard dawg
yeah, nice job.
I love homemade stuff. I learned a lot of stuff from a guy that always said handmade is always better. I believe he was right.
