Hi guys,
I want to filter my barrel aged spirits. Nothing dramatical, but I don't want any wood/dust coming over in the final bottle. I have a bottle filler ordered. And it comes with a filter.
Any of you have any idea on the optimal size of the filter? I get 3 choices: 5 micron, 1 micron and 0,25 micron.
Regards, Odin.
Filtering
- Windy City
Re: Filtering
Hey Odin
I as many do use coffee filters for my final product. I looked up the micron rating and found the average coffee filter to be 10/15 micron. I would think to use the 5 micron as it should be sufficient for what you want and plug up less then the smaller micron sizes.
Do you plan on putting spiced rum through this filter? I find I go through a lot of filters when bottling mine and would love to find a better way. Please keep us advised on how well this works
Re: Filtering
how about a sand filter? That be legal there? I have that some distilleries here use them
Deo Vendice
Deo Vendice
Re: Filtering
I'd imagine the 5 micron filter would work fine. I always use coffee filters and I never get sediment in the bottom of my whiskey bottles. I don't think barrels add much in the way of extra-fine particles.
Life member, representative, and proud supporter of the Hobby Distiller's Association.
http://www.hobbydistillersassociation.org
- Odin
Re: Filtering
It's the toast/charr particles I am most woried about. I think I will go with the 5 micron one!
Regards, Odin.
Regards, Odin.
Re: Filtering
i have actually found a small amount of particles in a bottle that has been sitting with out being touched for 6 months. its not a lot buts its there.
i use unbleached coffee filters . what micro , idk. it i was me i would go lowest micron filter i could get.
Re: Filtering
I'd go with the 5 micron and then if more filtration is desired just place a 1 micron in series after the 5 micron...
Re: Filtering
I use cotton wool in a funnel and push it a little
run about 100ml or till it is clear
then add back to the funnel
The Friendly Spirit
Re: Filtering
Just my 2 cent's worth
I'd find a readily available, cheap filter screen and build a simple and cheap filter system around it.
I'd also buy a couple filters with different micron ratings to see what works best.
