How/where to add Voltmeter to Heater element ckt?
If it plugs in, post it here.
varocketry
Post by varocketry »
I bought one of these digital display AC voltmeters a couple months ago that I'd like to install.
Blue digital LCD panel meter voltmeter circuit voltage monitor 2-wire AC 80-500V
Where / how should I install it in my heater element controller circuit? In series with the load? Parallel?
Here's my diagram of my element controller:
-Just need something else to build. -
Edwin Croissant
Re: How/where to add Voltmeter to Heater element ckt?
Post by Edwin Croissant »
In parallel on the mains only.
If you connect it in parallel over your element this voltmeter will smoke :( , see this thread.
This makes is not so useful as you will only measure the 120 or 240 Volt of your mains supply.
"In all affairs, it’s a healthy thing now and then to hang a question mark on the things you have long taken for granted.”
Bertrand Russell
In parallel with the load.
varocketry
Maybe its the Monday morning thing after spending the weekend trying to keep up with CROWEATER, but ... which location for the connection ... a or b?
Kegg_jam
Post by Kegg_jam »
(A) will read your line voltage.
(B) will read the load voltage but possibly blow up.
Edit: if it doesn't blow up it most likely won't read the correct voltage unless it is a True RMS meter.
bluefish_dist
Post by bluefish_dist »
Even if it reads line voltage, you still have amps to get an input wattage. That is a repeatable setting and makes life much easier. Amazing that we can get this technology for $10 now.
Formerly
Dsp-CO-20051
You have to be careful with that style of digital meter because they will fry if not supplied with at least 80 volts... That is the downfall of digital versus analog meters...
bluefish_dist
You really want the volt/amp meters. Using a super simple controller the line voltage does not change. Only the amps change at lower settings. As others have stated if you mount them after the controller to measure element voltage you will destroy the meter.
Formerly
Dsp-CO-20051
varocketry
Thank you for all the advice and answers, I do have a 25A analog Ammeter installed already.
