Andrew_90 wrote: ↑Sun Nov 21, 2021 7:25 am
The bottom bottle has a Gardena male.........The launcher is a female Gardena ..................... The bottles are pumped to a couple of bar.
Of course we now know, that your talking about something like this:
- changeshot004.jpg (6.88 KiB) Viewed 2667 times
But as far as I'm concerned, a "Gardena fitting" isn't common language. So I had to look it up. If you Google-up a "female Gardena", then you get a bunch of pictures that look like this.
Of course I knew what you meant by "bar". Barometric pressure (1 bar = 1 atmosphere)
approximately . In SCUBA, 2 atmospheres means your body is being squeezed with 2(14.7 lbs / sq.in.) pressure; and that you are about 33.8 feet down.
[You can hang around at that depth as long as you wish or untill your air runs out, which ever comes first. But if you dive down to 4 atmospheres (100' / 30m), you should only stay for less than 19 minutes (any longer requires decompression)].
I looked up barometric pressure to remind myself of a few facts. Everything has gone to metric, which is not welcome, but is no surprise. I don't like pesky “pascals”, just like some children don't like to eat their spinach, or beets or liver. But then a
“bar”or a
“millibar” which are so common and so frequently mentioned,
are not even officially recognized SI units!
Pishaw...
1 bar = 100,000 Pa
1 bar = 0.1 MPa
1 MPa = 10 bar
Some newer aneroid barometers don't even sport an "inHg" scale any more.
1 bar = 14.7 psi
A normal (antique) barometer needle should hover between 29.8 and 30.2 inHg (inches in Mercury). Unless a storm is coming.
