I purchased one of the specific gravity floats (for light fluids) and another for heavy. It does not have the % Alc on it. It measures in specific gravity.
How do I do the calculation to give me the % Alc? After I have distilled my batch?
On a personal note, I am really looking forward to my first batch. I just picked up a bunch of supplies to make a still. I am making the tubeing modular so depending on the tube you attach it moves from being a pot/reflux/fractionating. One could also put a jar in the middle for botanicals. I am making the reflux attachment first.
Brendan
Specific Gravity & Alc %
pHneutral
Re: Specific Gravity & Alc %
This table is a bit small, but it has what you need on it. Zoom in on it and you should be all set. It goes all the way from 1.00 to 0.793
http://journeytoforever.org/biofuel_lib ... fig5-3.jpg" onclick="window.open(this.href);return false;" rel="nofollow
and the correction table for temp is here
http://journeytoforever.org/biofuel_lib ... fig5-4.jpg" onclick="window.open(this.href);return false;" rel="nofollow
Modified versions of those tables can be found elsewhere here in these forums... Someone went to the trouble of recreating them from scratch... Perhaps they will post internal links here...
SuperDavid
according to my beer brewing handbook......you find the difference between your sg and your fg and divide it by 7.36.
HookLine
I did one of them a while back, just a straight copy in larger text.rad14701 wrote:Modified versions of those tables can be found elsewhere here in these forums... Someone went to the trouble of recreating them from scratch... Perhaps they will post internal links here...
Be safe.
Be discreet.
And have fun.
Be discreet.
And have fun.
- Husker
This is how you determine the ABV of a wash/mash. The other spreadsheet of numbers simply tells you the % ABV of a mix of pure water and pure EtOH.SuperDavid wrote:according to my beer brewing handbook......you find the difference between your sg and your fg and divide it by 7.36.
There are different hydrometers which measure each of these types of problems. The one that SD mentions, is used to compute ABV of a beer/wine to determine how much sugar has been converted into EtOH. The other links provide (and sheet inline uploaded), are of the same 'scale' as a alcoholmeter is set to test. In that form, you are only able to test a distilled spirit which has had no other things, such as sugars or juices added.
Since knightt originally asked this question:
it is obvious that a simple alcoholmeter is the proper tool (that along with a thermometer). However, if he has hydrometers that are simply calibrated in SG readings (SG of distilled water being 1.00), then he can obtain the actual SG reading (and temp), and use a lookup table (along with correction for temp), and come up with the same result as an alcoholmeter would give. The only thing an alcoholometer is, different than a hydro, is that it has a 'scale' that has 0 ABV at the bottom, and 96 ABV at the top (or possibly some other smaller range for more accurate units).How do I do the calculation to give me the % Alc? After I have distilled my batch?
H.
SuperDavid
oops...must have been half a sleep when I read the question.
knightt
Thanks.
The chart really helps!
Brendan
Brendan
knightt
Figured out the formula.
So, Water at 20 degrees is .99823 ethanol is .78934
A mixture of 1part water and 99parts ethanol would look like (.99823/100*1+.78934/100*99) = .7914289
hmmmm. Now to figure the formula to a start with a sp and "know" the alc %. ok.
Got mathematically inclined a friend to help me.
Water% = (SG - 0.78934)/0.20889
I think I might be able to make a single formula to figure alc %.... Maybe not.
One could probably drop a couple of the decimal points and still come up with an accurate number.
These numbers are calibrated at 20 degrees.
