Heating Element Control in Pot Distilling
ammo man
Post by ammo man »
I must be missing something here. Since I ordered my router control to control the heat of my hot plate that I use in pot distilling, I have been reading everything I can find on the home page and by searching the posts relating to temperature in pot distilling which by the way is a lot. But I cannot find anything on controlling the temperature of the heating element. Everything is about the temperature of the vapor.
It is my understanding that ethanol alcohol boils or vaporizes at around 78.1C which changes according to elevation and barometric pressure which I understand. Why cannot one tweak the heat of his heating element by using his alcometer to determine when his output is pure ethanol alcohol from a pot distiller which as I understand is 95.6% abv without chemical treatment? I fully understand as you are heating the wash to that temperature you will distill all the fusel alcohols that boil or vaporize at a lower temperature, but after you reach that temperature, everything thereafter will be pure ethanol alcohol.
The reason I am pot distilling is because I want some flavor in my drink, and I do understand that pure alcohol is tasteless and odorless. What I am leading up to is why can't I by experimentation find a temperature for my heating element that will produce say an 80% abv which from what I read is about where the flavor begins, or for that matter a less abv according to my taste? I know that there are a lot of factors to consider, but for a given recipe you usually have the same % abv in each wash, and once you have found your temperatures one time, then there would be very little fine tuning you would need to do to adjust for different barometric pressures, and so forth.
I know that some, if not all, of you old master distillers are thinking why the hell I just don't do my cuts until I get what I want. More than likely this is what I will end up doing, but heck, nothing ventured, nothing gained. Why not tread new ground, or do something that is not usually done. And I do like to experiment.
If my reasoning above is not correct, I earnestly ask that you correct me. In any event all comments, negative or positive, are welcome. Thanks in advance.
Bert
Re: Heating Element Control in Pot Distilling
Recon with enough practice you could dial in all the variables to get repeat performance.
But how do you dial it in without the ability to make adjustments during your learning curve? You will only get generalities when asking for help as almost everybody has a slightly different set up.
Temp of the element/wash is a non issue really as the alcohol content will dictate the wash temp. As the alcohol depletes, the temps will automatically want to rise as the ratio between alcohol and water changes. Adjusting the element to a lower setting may mean (at this point of the run) that you may stop your out put.
Better to install steady input an make (controller) adjustments according to the thickness of your (output) stream.
Hope I read your question correctly.
Dnderhead
Post by Dnderhead »
first,, you can not control the temps. of neither the wash or the vapor, this will depend on the amount of alcohol in the wash/mash and the vapor, next ,,very doubtful you will git 80% alcohol the first run, more like 2-3 runs to achieve that in a pot still.this will depend on the % of wash/mash you put in the boiler.and how fast you run.
ammo man
Post by ammo man »
Thanks for your speedy responses.
I guess I am not thinking straight, or understand some of the theory. I do not want to control the temp of the wash nor do I want to control the temp of the vapor per say. I want to control the heat of my element. The way I am thinking is that if my heating element is say 80C, I am applying 80C of heat to the wash. Anything in that wash that vaporizes at 80C or less will then vaporize. After all of the 80C or less stuff is drawn off, then no more vapors and no more output. I don't understand how my wash can become hotter or less than 80C nor my vapor can become hotter or less than 80C if that is the heat I am applying.
Please explain. Thanks again in advance.
Bert
I would use the alcometer to measure the %abv of the output to determine what to dial in.
ammo man wrote:I don't understand how my wash can become hotter or less than 80C nor my vapor can become hotter or less than 80C if that is the heat I am applying.
The boiling point of water is 212 and the boiling point of alcohol is 173.
A 12% (or 14 or 8 for that matter) wash will not boil at 212 or 173. It will boil at some point/temperature in between.
Once the liquid reaches its boiling point it will vaporize,,,,,,and exit the boiler. If the element is 250 degrees the boiling temp of the liquid will still be somewhere between 212 and 173. If the element is 350 degrees the boiling point of the liquid will still be somewhere between 212 and 173. All the while exiting the boiler.
No matter what the temp of the element is, the boiling point of the wash is always somewhere between 212 and 173
No such thing as 300 degree boiling water (as an example).
Am i saying this the right way?
kiwistiller
Post by kiwistiller »
Yup, in a nutshell, you can't control the boiling point of a mixture of fluids. It will boil at whatever it pleases, and that will increase as the mixture changes.
Here is a picture that might help? or might not. It is a graph showing how the boiling point (and therefore vapour temp) changes over the course of a run, as ABV in the boiler is dropping. click on it to expand.
The way boiling points work is under the boiling point in temp you produce next to no vapour. and you can't go over the boiling point, all it does is boil faster when you apply more heat.
Does that help a bit?
Three sheets to the wind!
My stuff
kiwistiller wrote:all it does is boil faster when you apply more heat.
There ya go. I couldn't spit it out :? :)
ammo man
Post by ammo man »
I tend to be on the "hard headed" side. I'm just gonna have to wait until my router control gets here and test it.
I understand what you all are saying about the boiling point of the wash, but I am not interested in the boiling point of the wash. I am interested in the boiling point of ethanol alcohol. Unless the laws of chemistry have changed since I studied them many years ago, If the boiling point of ethanol alcohol is 71or so degrees C, then when that temp is applied, it will boil. Don't care what it is mixed with. Why should I worry about the wash boiling or not? As I said above I am not interested in that. I am interested in the boiling point of the alcohol.
BTW I am not from Missouri, the show me state. I am from Texas, the you gotta prove it to me state. :egeek:
Bert
kiwistiller
You should care about the boiling point of the wash and not the boiling point of the ethanol that is part of it, because NONE of the mixture will boil until you reach the mixtures boiling point.
Example:
you have a boiler charged with 10% wash. This is going to boil at roughly 90 degrees C. Lets say you hold the temperature of the mixture at, what, 85C to be safely above the boiling point of the ethanol in there, around 78 or whatever. Nothing will boil, because it is below the boiling point of the mixture. It will steam a little, like a cup of hot coffee, but won't truly boil.
Analogy:
You know how you add salt to boiling water to raise the temp that it is boiling at? Same thing. When stuff mixes, the rules change.
If you aren't a cook and don't know about the salt thing, it is also the same principle at work when you add antifreeze to your car radiator- it mixes, and then lowers the freezing point. Incidentally, it also raises the boiling point, which is good in summer.
I don't get the bit about states, but I suppose if I have to ask I'll never know :lol:
But yeah, if you want to try it, go for it :)
My stuff
Yes Bert,
The alcohol will blend/dilute very nicely with water.
It's not like an oil slick that will stay stratified.
Dnderhead
Post by Dnderhead »
To put it simply,it is much like boiling potatoes,you bring it up to a boil then turn it down to a simmer.then just leave it there.
the temps.will take care of themselves.
MuleKicker
Post by MuleKicker »
I think i know what your asking bert, and it doesnt work that way. Your saying, why cant you hold the wash at say, 80c through out the run and just get the alcohol. Once your temp gets to 80 and you deplete that level of alcohol, the vapor trail will taper off, your wash will remain at 80, but nothing will be coming out the other end. I used to have this way of thinking, once you start playing with yer rig, you will understand completely. Chasin temps dont work. Its all about heat input. Temp readings are just a novelty. (maybe a way to judge alcohol content in wash/vapor, not control it. )
-Control Freak-
AKA MulekickerHDbrownNose
ammo man
Post by ammo man »
From http://homedistiller.org/" onclick="window.open(this.href);return false;" rel="nofollow Under Distilling > Distilling the Wash and down to Using the Pot Still we have:
Using a Pot Still
A pot still is fairly straight forward to use. Turn it on. Once the temperature is up to about 60 °C turn on the cooling water to the condensor. Make sure you throw away the first 100 mL per 20L wash, as this will contain any methanol that might be present. Segregate the distillate into 500 mL lots as it comes off. Only keep (for drinking) that which doesn't contain fusels (smell off) - probably below about 92 ° C, however you should keep distilling past here, untill about 96 ° C, as this fraction, although high in tails and not good for drinking this time, can be added back to the next wash and cleaned up OK then.
Graham describes using his ...
I single distill as I have no need to purify my spirits. The concentration at the top of the tower can be controlled with how much heat i apply at the bottom. If I want a pure spirit, I apply a low heat and can run it off at over 90%. with a bit of a twig I have hit the magical 97.5%. But you get utterly no flavours. I apply more heat, so I get a run at about 70 to 80% and get the flavours I need. Its true people, about about 80% you start to lose flavours.
I normally cut my runs when the alcohol drops to about 40%. The heat put in compared to what I get isn't worth it.
Someone pointed out to me that Graham said "the top of the tower" so he must have been talking about a reflux still. I sort of find this hard to believe since it is under "Using a Pot Still". Would someone please explain the above to me?
I am beginning to see a little light at the end of the tunnel when antifreeze and salt were mentioned, but I still got to see for myself. As soon as my control device gets here I will run some experiments to convince myself one way or the other.
Bert
MuleKicker
97.5%? Thats not possible. Also he could be talking about the "tower" as the top of the still, before the lyne arm? Not sure on that one. Where did you find that quote?
-Control Freak-
That is just one of many inaccuracies on the parent site... Unfortunately, we don't have permission to make changes to what is becoming antiquated information over there... The information you have been given multiple times here is the accurate truth, however, ammo man...
kiwistiller
I believe the post in the parent site was probably talking about a power management reflux column - tall packed uninsulated pot still. run it slow enough and the passive heat loss will make it behave like a forced reflux still.
My stuff
ammo man
Post by ammo man »
Thank you rad. As I said I am beginning to see just a little light at the end of the tunnel.
I want all of you to clearly understand that I am not for a minute implying that anything you have said is not true..
It is just that my old mind does not work as good as it did many years ago. I have always been slow in my thinking, but usually in the end I fit the pieces of the puzzle together. However, I still am going to do some experimenting to fully convince myself.
To answer kiwistiller question about the states. I meant that I do not always believe what I see. Sometimes I need proof. And for that matter I learned many, many years ago not to always believe what I read.
Thanks fellows.
Bert
kiwistiller
No worries mate, sometimes you gotta rotate the piece of the jigsaw by hand before it falls into place. Besides, tinkering with stills is awesome.
My stuff
No time tinkering with stills is wasted time... Almost seems like a miracle every time that first drop of alcohol comes out of the still... :D
Rod
Post by Rod »
If you want to control your heater element
try sultronic
see my post
http://homedistiller.org/forum/viewtopic.php?f=2&t=8002
The Friendly Spirit
ammo man
Post by ammo man »
Thank you Rod for that information, but I have on order a router control, about $35, that will do the trick.
Bert
