Twin Slant Plate the full still -- Liquorice Stick
still crazy
Post by still crazy »
Building a Twin slant plate stick still for a member figured I would document.
Anyone whos interested in one PM me and I will see what I can do for you.
The build:
A 50" total length still
36" of column for copper packing fit with a easy flange bottom for keg mounting.
12" of condenser space for a cold finger condenser
2" of twin slant plates with take off and temp port sandwiched between
Photos below
still crazy
Re: Twin Slant Plate the full still -- Liquorice Stick
Build continued
WalkingWolf
Post by WalkingWolf »
I like that jig you got there SC. Good job
still crazy
Things the bomb slip on the pipe wedge for tightness and go to town, two cuts, two holes, 5 min.
The band-saw works magic too since copper is non-ferrous and can be cut with a nice thin wood blade.
Very well documented build, still crazy... The only thing missing is installing the plates and tubes, which some think is tricky even though it's easier than they think... I'm sure the recipient of this column will enjoy years of use with it...
britincali
Post by britincali »
Ohhhhh Yes im excited now :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
beelah
Post by beelah »
Nice build and I also like the jig. I think I am going to have to make myself one aswell.
still crazy
Few more pics
Parrot on column
Cold finger
britincali
Absolutely friggin BEAUTIFUL!!!!!!!!
Im gonna start a birdwatchers wash tomorrow so hopefully the timing will be perfect :D :D :D :D :D
oakspring
Location: In the High Country---------right about there--->
Post by oakspring »
NOW THAT IS SLICK!!! Nicely done... :D
condensificator
Post by condensificator »
all around great stuff. design, planning, jig, fabrication, documentation. killer. the dump valve on the parrot has proven to be one of my favorite additions to a "standard" setup. i'd consider it a must now. makes switching collection containers super easy and lets you drop heads/foreshots without running it through the good hole.
i keep talking my friends into getting into the hobby, a lot of them don't have the tools or skills to make something like this...how much do you charge for a rig like this one?
kudos!!!
still crazy
Final photos
Boxed for shipping
Like sending a kid off :cry:
britincali
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin:
WalkingWolf
That's fine workmanship there BD. You sure as hell wasn't blind drunk when you put that thing together.
Congrats to you britincali on getting one fine rig. May you enjoy many bountiful runs. :)
ww
britincali
Checks in the mail and Ive got 2 washes going, one 5 gal one to clean her out and a 15 gal one for the good stuff! :D
It feels like waiting for friggin santa on christmas eve :oops: :oops: :oops: :oops: :oops: :oops: :oops:
emiliokiedoke
Post by emiliokiedoke »
doesthe cold finger eliminate the need for a condencer on the take off?
gretschem
Post by gretschem »
Can somebody explain this still ???
What it does exactly, what kind of spirit does it produce ???
Thx
olddog
Post by olddog »
gretschem wrote:Can somebody explain this still ???What it does exactly, what kind of spirit does it produce ???
It's a twin slant plate Bokabob reflux column, it is designed to produce neutral spirit
OD
gretschem
Post by gretschem »
OD
Ahh thx OD. I guess that's why it's called a liquorice stick, for making vodka huh ???
olddog
Post by olddog »
gretschem wrote:I guess that's why it's called a liquorice stick
Nah, some of us give our stills names.
OD
emiliokiedoke
maybe let the parrot perch 12 inc lower sling a lil weinie in the middle
britincali
Got her today and god damn its even more beautiful in person!!!!
Took a little hit on the condensor but aside from that perfect.
Gonna run her on tues :D :D :D
britincali
Third run this morning and Ive got her dialed!!!!!!!
Queen of hearts
Post by Queen of hearts »
I am new at this so I am not sure where to ask this question. But here I go. I like the idea of building the parrot onto the side of the column (Liquorice Stick) my question is: if the out put cup on the top is a 3/4" to 1 1/4" reducer (which is what I used) the actual stem of the parrot is 3/4 " can I put a 1 1/4" pipe over the whole thing to act as a water jacket and use a branch of my cooling line to cool the actual parrot or is that liable to change the measurement of my alcohol content. I would put a valve on the input water cooler line to regulate flow and hopefully temperature. Also should I put a T on the bottom where the recently distilled product enters the parrot from the bottom both to drain off the foreshots and also empty the finished product still remaining in the parrot back toward the finished product holding container when the run is complete? I notice if I slip a 1 1/4" pipe up against the widest part of the 1 1/4" x 3/4" reducer with the 3/4" end sticking back in the pipe it almost makes a flush fitting and I think I could make a perfect solder connection. I will have to come up with a bottom connection but I can build any of this, but in conclusion if I cool the actual parrot stem will that have adverse effects. I only want to build this once and I want it as perfect as I can get it. Thank you in advance for your comments and thoughts. I am sure If I build this I can eventually determine if this will work but for now I would like to not have to learn everything by trial and error. I can also draw this up and put in through my scanner if everybody has a problem understanding my convoluted question.
still crazy
You can cool your distillate as it come out.
Any reading you take with an alcohol meter has to be corrected for temperature.
The method you envisioned will work.
On my personal still I ran my output line along a liebig on the VM portion of the still.
This cools the distillate prior to entering the parrot.
Usge
Post by Usge »
I have the same issue with my boka (distillate comes out hot). I just put the parrot in a pot of cool water. Worked fine.
Queen of hearts
Excellent. I just took two 8" stub outs, cut 2" inches off each one (giving me a total of 12" including the coupler. Cut a 1/4" hole at each end. Ran a 1/4" tube through, wrapped it with 12/2 copper wire and added 1/4" in-flow and out-flow stubs at each end on opposite side on the 1/2" stub outs. I will tap off the coolant water. Hopefully it will keep the product cool when it enters the parrot. My plan is to attach the product cooler (maybe you could call it a mini liebig) to the column and then attach the the parrot to the mini liebeg. I am flying by the seat of my pants here as I am just trying to build things based on the different designs I have seen so far all on these posts. I also cut my slant plates today from the the template but they seem to be maybe a little of the small side. I am going to make them bigger so they over hang the column and then grind off the excess. Oh I love this shit. I am going to have a great looking still, who the hell knows if it will work, but I am going to have a great time building it regardless. I spent a couple of hours today in a plumbing supply place fondling the parts, not as good as the real thing but still a boat load of enjoyment. :twisted:
6fiddyv
Post by 6fiddyv »
just brilliant, thinking outside the still...hahaha. Hope you dont mind, im gonna use some of these fabulous ideas on my build. That parrot valve is genius. Think its a must have, both time and contamination of sorts to the hearts...
Of course I will give credit where credit is due...just not right to not give it.
6
Total Abstinence is the way to handle the Alcohol Problem...circa 1891
engraved on a water fountain in the town I was born...
McIndy
Post by McIndy »
Finally, I found this a while back, then ended up building a box like yours from memory. Turned out alright, but wasn't sure i trusted it. After researching for this thread for a week, I FINALLY re-discovered it! Woo WHOO! and its just in time because i have all day tomorrow to build my boka!
Ill let ya know how she turns out!
McIndy :thumbup:
The EXPERT in anything was once a BEGINNER.
McIndy
Post by McIndy »
How did you assemble your jig? Looks like from what I can tell, one piece of 4x4 hollowed out somehow?
McIndy
