Told her I would have to build a reflux attachment for my still and I've never run a reflux before but..I guess I could if she wants it.
So here's the problem, I started looking at various types and the one that seems easiest to build would be Rad's. I was thinking of using 2" tube and building a 4' one with a furrel to clamp on my keg so I can swap from pot to reflux.
The problem; how does a reflux work?
I understand the reflux of liquid back into the pot etc, I mean what is the difference if I take off from a valve on the side, or take off from the top like a potstill? I guess I don't see how it's any different. Liquid turns to vapour and travels up, it either goes into the lyne arm (pot) or hits the cooling coils and falls back into the pot(reflux)
I'm thinking if I wrapped a cooling coil around my 2" verticle tube going to the lyne arm I could reflux it that way too right?
Right now my set up is a triclover clamp on 10-12" of 2" then changing to 1/2" and then on to the lyne arm. What if I made a potstill head with 4' of 2" then change to 1/2" and then onto the lyne arm.
Anybody understand or did I just confuse the heck out of everybody?
![Image](http://i23.photobucket.com/albums/b400/goinbroke2/100_1096.jpg)
Ok, here is a pic of the still head. What if I made one 4' long and added cooling coils around it. Wouldn't that work?
Or should I just build a ...whatever Rad's is called?
Either way..for some reason the reflux thing doesn't make sense. Is it because so much gets refluxed as opposed to a potstill which takes everything off?
