Well, I have been doing a lot of reading, and I think I will be going with a Bokakob design for my first project. I have unlimited access to free 2.5" copper/unions....limited 2". Playing with the 2.5" seems the best option since we have a lot of it, but the plans I have seen thus far deal mainly with 2". Doing my research here tells me that my column using 2.5" should be 5'. I have been trying to design the condensor/head for this and haven't found an easy conversion from the 2" to 2.5" copper. I have done some calcs on paper, but, I am not sure that gaps on the design are within specs. Also, I would appreciate some guidance on the total length of the condensor/head assembly. Here's my thoughts on the condensor build minus the total length....dealing with just the dia right now.
1. 1/2" cold finger
2. 1/4" "soft-rolled" tubing for the first wrap over 1" mandrel.
3. 1/4" second wrap over 1.5".
The result of this will be 1/4" between the cold finger and the inner edge of the first coil wrap, 1/4" between the first/second coil wrap, and 1/4" gap between the outer edges of the condensor assembly and the inner edge of the 2.5" pipe......this, if I calculated correctly, should result in a space of 6.35 mm between the outer edge of the condensor assembly and the inner surface of the 2.5" pipe. I am sure that this spacing of 6.35mm won't choke the head, but, is it too much as to create blow by of the vapor?
I am learning here...as the above will show, so don't feel bad about stinging my feelings. I am sure Rad will.
TIA, for any help.
Len
