Time for copper pics
still crazy
Post by still crazy »
Here's the new toy.
When shes mounted on my 10L SS fire extinguisher boiler she stands in at 7"''-10" << got a 8' ceiling.
Full view she stands 6 feet tall.<br />40&quot; column with 3 types of plates. 8ea of type A,B &amp; C<br /> A) 2&quot;dia. 1/8&quot; multiple drilled 25% full fit  B) 2&quot; od with a 1&quot; hole &quot;donut C) 1 3/4&quot;od half sphere.  <br />All are center mounted on a 3/16&quot; copper rod<br />Takeoff utilizes a 1&quot; VM takeoff port that goes to a 1/2&quot; inside a 3/4&quot; liebig. I use this for stripping. <br />She also has a 1/4&quot; valved reflux port based on a Bokakob design.<br />This feeds into a tee which splits into a foreshot collector (not installed during photo) then to the parrot.  <br />The parrot incorporates a bypass and a drain valve to the collection leg.
40" column with 3 types of plates. 8ea of type A,B & C
A) 2"dia. 1/8" multiple drilled 25% full fit B) 2" od with a 1" hole "donut C) 1 3/4"od half sphere.
All are center mounted on a 3/16" copper rod
Takeoff utilizes a 1" VM takeoff port that goes to a 1/2" inside a 3/4" liebig. I use this for stripping.
She also has a 1/4" valved reflux port based on a Bokakob design.
Condenser is 16&quot; length of 2&quot; shell with a 16&quot;long 1 1/2&quot; cold finger. <br />The cold finger is wrapped with 1/4&quot; o.d. tubing which is coiled around the cold finger. <br />A 1/4&quot; space between the windings of the coil forces Vapor to spiral up toward vent &lt; no vapor escapes
Condenser is 16" length of 2" shell with a 16"long 1 1/2" cold finger.
The cold finger is wrapped with 1/4" o.d. tubing which is coiled around the cold finger.
A 1/4" space between the windings of the coil forces Vapor to spiral up toward vent < no vapor escapes
Close up of 1/4&quot; tubing to parrot, the lil red cap is where the foreshot collector mounts, the circular ring swings aside to allow the collector a shelf.<br />The tube to lower end of parrot is tacked to the liebig which will cool the takeoff for better readings.
Close up of 1/4" tubing to parrot, the lil red cap is where the foreshot collector mounts, the circular ring swings aside to allow the collector a shelf.
Lower end of the liebig and parrot tube outlet into collector leg.
Side view of the valving and thermometer port, I use a #3 cork and pinched the 3/8&quot; i.d tube to keep it from being pushed in.<br />&gt;&gt;Thermometer has been replaced with a digital read unit.&lt;&lt;
Side view of the valving and thermometer port, I use a #3 cork and pinched the 3/8" i.d tube to keep it from being pushed in.
>>Thermometer has been replaced with a digital read unit.<<
rubber duck
Re: Time for copper pics
Post by rubber duck »
That is a nice build. I'll be looking forward to hearing about how it runs. Nice narration on the parts, I always like that when I'm looking at something complicated.
olddog
Post by olddog »
Great looking build. How does it perform?
The only fault I see, is that it would be even better mounted on a Keg.
OD
Fester
Post by Fester »
ooooooh, aaaaaaaah, NICE!
a rig like that should crank out lots of vodka/neutral spirit.
very clean looking build. craftsmanship.
i'm thinking that your 10 liter boiler will get upgraded soon :D
with a build like this i think you will want a bigger better boiler
fester
Fester
Post by Fester »
it is so pretty. how did you polish it? and what is that blue stuff in the joints in the last picture? a silicone to seal joints together?
kiwistiller
Post by kiwistiller »
So do you use the VM for stripping and the LM for spirit runs? what do you do with each option?
EDIT Just re read... so the LM is for heads extraction, and then do you go back to VM? the one thing that puzzles me is your comment that you use the VM for stripping, I would have thought the LM would be more suited.
Three sheets to the wind!
My stuff
Nice combo rig, still crazy... My only concern is the thermometer placement... It is in the reflux liquid path rather than in a primarily vapor path... Reflux liquid may skew your temperature readings... You'll know soon enough whether placement is a factor or not...
Good luck with testing... Keep us posted...
rednose
Nice built
Post by rednose »
Looks like modern HighTech, great looking built SC, congrats.
Joe
still crazy
rubber duck wrote:That is a nice build. I'll be looking forward to hearing about how it runs. Nice narration on the parts, I always like that when I'm looking at something complicated.
Duck
I do stripping runs at a higher heat setting. Use my plumbers turbo torch with the 3/4" nozzle on high till she spit then turn it down till the flame just flutters and let is go till the output goes tails and starts to turn milky. With a soft flow of water it takes 1 1/2 hours start to finish to strip 10L of 14% birdwatchers.
When I have four stripping runs done I mix everything about I stripped about 3 1/2 L (3600ml) with 6L of distilled water (I inherited a medical distiller) and do a reflux run.
Dump the first 250 ml foreshots. Collect 300 ml heads. Then collect 200 ml at a time. Keep the jars numbered and when it goes to tails let it run out till the temp climbs.
Starting from center out I combine the 5 center jars (94% abv) into (2) 1L bottles mix it with distilled mark it "bullseye".
The next two on either side from center get into a 750 ml bottle to be flavored or aged with char later.
The remainder gets stored for the next reflux batch. Which is the next 20L strippings and this way I meld batches
Have run 12 strips to date and the consistency is super.
rad14701 wrote:Nice combo rig, still crazy... My only concern is the thermometer placement... It is in the reflux liquid path rather than in a primarily vapor path... Reflux liquid may skew your temperature readings... You'll know soon enough whether placement is a factor or not...
RAD
Straight up thanks for warding me off the CM I was originally going to build. Made me take a step back re-read and scheme this bad dog together.
Ya that temp port reads high but I caught on to it right away, got a digital now, and by my 3rd run had my own adjusted temp chart for running it.
Didn't raise the bridge, I lowered the river.
Waited till I had 100 # of sugar thru her till I polished her up for pics. <<< ed note THE WIFE POLISHED HER UP FOR THE PICS <gotta give props>
kiwistiller wrote:So do you use the VM for stripping and the LM for spirit runs? what do you do with each option?
Kiwi
I use the 1" port (ball valve) VM and open her up about a third to strip. Monitor it to a pencil lead drip and collect everything no cuts.
See reply to Duck above.
When running full reflux I slow down the output to a nice quick drip and do cuts with the LM.
I value your input so any suggestions would be definitely looked at hard.
Fester wrote:it is so pretty. how did you polish it? and what is that blue stuff in the joints in the last picture? a silicone to seal joints together?
Fester /Old Dog
Wife takes all the credit for the polish she plugged the outlets with rubber corks and used Tarn-X. I even saw a toothbrush in there. Got to put her back in her insulated jacket, the copper that is, now that shes been documented.
I have (2) 1/4 pony kegs and am awaiting the clamp to use that boiler so your ESP was right on.
The blue stuff, its actually muddled gray in the right light, at the joints might be the type solder I used it super high tensile strength we use for fire sprinklers copper systems. Kinda a bitch to get it to flow but when it does its foolproof ,,,"the problem with making it foolproof is that fools are so inventive"
Any how my first clean was with salt and vinegar and that's when it turned color. ????? It is 95% tin with a lot of silver, lead free.
kiwistiller
snips:
still crazy wrote: Ya that temp port reads high but I caught on to it right away, got a digital now, and by my 3rd run had my own adjusted temp chart for running it.
That's interesting, I would have thought that reflux temperature would be lower than vapour temperature, considering it has been cooled and condensed.
still crazy wrote:Kiwi
I would have done the opposite, personally. With stripping all you normally want is a quick and dirty distilation, and LM is much more suited to this, as the reflux ratio can be taken down below 1:1. The VM will be a better performer in the spirit run, as the reflux ratio will remain constant to the setting you choose over the course of the run. Hit me back if you want elaboration on this. Or do it your own way, whatever works for you is great by me :D
Anyway looks like a beaut piece of work.
My stuff
HookLine
Post by HookLine »
Tin based solders do not like acid (or alkaline) conditions. The salt probably does not help either. But that blue-black shit should clean off pretty easily.
Be safe.
Be discreet.
And have fun.
Samohon
Post by Samohon »
Looks complicated. But I understand the concept...
Nice...
S.
♦♦ Samohon ♦♦
azeo
Post by azeo »
Very inspirational! I like the way the various attachments, tubes and controls have been mounted and routed, that's often a hard (effort wise at least when sometimes you want something going NOW!) part of the job to finish to satisfaction and safe practical use. Nice work, enjoy!
still crazy
Few more pics
Some in operation
The boiler General model WS800 2 1/2 gallon (10L)<br />Has a 2 1/2&quot; fine threaded top with a set of lugs so you can disassemble by hand.<br />Drilled out the top and installed a 2&quot; threaded copper lined brass nipple.
Has a 2 1/2" fine threaded top with a set of lugs so you can disassemble by hand.
Drilled out the top and installed a 2" threaded copper lined brass nipple.
Will be doing a strip run so using major heat<br />65f to 173f in 20 min
My fire extinguisher (10L) boiler<br />Use a General model WS-800<br />Has the wide mouth with a swivel nut top<br />Durarock baseplate with red brick stand<br />3 different turbo torch nozzles
Foreshot collector ready to go to work<br />The open tube in the rubber bung on the left can be set at whatever ml level you need to remove.<br />Its foreshots and will be tossed so not in the vapor path.
Set up and heating<br />Doing a stripping run <br />See the 1&quot; clearance of the ceiling to stilltop<br />I know the pony keg instead of the fire extinguisher as a boiler.  Only doing 10L today.
Set up and heating
See the 1" clearance of the ceiling to stilltop
still crazy
These are pics of a mini bok I build while doing (2) 10L stripping runs from left over copper parts.
Have to get some scrubbers and figure what to use as a boiler to test it.
If it works good think I will put em on ebay
The four pieces<br />Left to right<br />The condenser has a return line that runs down from top to bottom from cap<br />The coolant feed line is tapped into the side of the 1/2&quot; tube<br />A flattened piece of 1/4 tube is tacked on as a band<br />The condenser shell. Just a piece of 3/4&quot; M<br />The slant plate head is detailed in other pic<br />The tower is a 1&quot; pipe with a coupling <br />Will pack with scrubber and build attachment for boiler soon
The four pieces
Left to right
The coolant feed line is tapped into the side of the 1/2" tube
The condenser shell. Just a piece of 3/4" M
The tower is a 1" pipe with a coupling
The 1&quot; slant plate head with temp port<br />Temp port is a piece of tacked in 1/4&quot; tube
The 1" slant plate head with temp port
Temp port is a piece of tacked in 1/4" tube
Here's the whole thing thing assembled.<br />That's a yard stick, meter stick i should call it, beside it.
blanikdog
Post by blanikdog »
Great work SC. Almost too nice to use. :lol:
blanik
Cumudgeon and loving it.
still crazy
I will add my keg and keg adapter pics here.
Descriptions are with pics
EDIT I deleted the pics cause while it didn't leak the coupling was toooo wobbly and I felt it was unsafe went to a standard 2" Sankey coupling.
diesel4ever
Post by diesel4ever »
Holy crap! That thing is... superfluous.
ozone39
Post by ozone39 »
It would be interesting to see if Victraulic or Groove Lock made Teflon gaskets for their groove couplings (maybe for food processing applications).
still crazy
When I built my still I took some pics of my plate setup. They were trapped in my cell phone. I finally got them on a SD and can now post them.
This is how I built my 2" x 48" column that is pictured at the beginning of this post.
The levels of plates are set 2 3/4" apart. There are 3 types of plates and 8 levels of each style, There are 24 levels.
Here is a stack of my &quot;strainer&quot; discs in a jig turning them so they fit barely into my 2&quot; x 48&quot; column.
Here is a stack of my "strainer" discs in a jig turning them so they fit barely into my 2" x 48" column.
These are the 3 types of plates I used.<br />The one on the left fits tight to the column wall and puts the reflux back in the center of the column.<br />The center one is a strainer type and gets an inch coating of 3/8&quot; dia marbles on it.<br />The one on the right is a catch and splatter type, it is made of 1 1/2&quot; test caps hammered on a 2&quot; trailer ball.
The center one is a strainer type and gets an inch coating of 3/8" dia marbles on it.
The one on the right is a catch and splatter type, it is made of 1 1/2" test caps hammered on a 2" trailer ball.
Heres the thre types of plates attached to a 1/4&quot; solid copper rod. There are 8 levels of alernating &quot;plates&quot;.  The strainer type plates get 1&quot; of glass marbles on top.
Heres the thre types of plates attached to a 1/4" solid copper rod. There are 8 levels of alernating "plates". The strainer type plates get 1" of glass marbles on top.
Made a jig to &quot;turn&quot; a stack of copper discs to barely fit into a 2&quot; column
Made a jig to "turn" a stack of copper discs to barely fit into a 2" column
still crazy
Finally decided to turn my 10L stainless fire extinguisher into a pot still stripper.
Found that a 1 1/4" female copper pipe adapter was the same thread as a water heater element for screw in.
Got this liquid flux at my supply house . This stuff is the bomb.
While i was soldering if the solder wasn't sticking just add a drop and retouch eeeeeeeaaaaasssssyyyyyy.
I was posting the pics and noticed I can almost see myself in em.
still crazy
Added a valve position indicator to the needle valve.
It is just a couple of # 12 wires twisted together and soldered for solidity.
Then I tacked a pointer wire onto the needle valve knob.
Now its easy to see the tiny movements of the knob.
still crazy
For the season I spun a web
Copper of course
Seems like every time the wife says I have too much time on my hands, I prove it!
King Of Hearts
Post by King Of Hearts »
Houston, we're ready for take off. Nice job. I couldn't even begin to figure out how it works.
still crazy wrote:Seems like every time the wife says I have too much time on my hands, I prove it!
Yup... :roll:
