![Image](http://i270.photobucket.com/albums/jj85/tfmahony/resize.jpg)
I mentioned that I would post photos of my project, so here is what I have been working on. This unit consists of a 2” diameter vapor column that is about 45” long. The condenser consists of 3/8” diameter copper in a 3” diameter shell. The coil section is 12” long with the housing about 15” long. This will mount on a 13 gallon milk can and be heated with a natural gas burner. I intend to regulate the burners gas flow with a ball valve and the same for the condenser water supply. I also have insulation for the column and boiler.
The column is intended to be a take down unit, the coupler used on the column is a “no stop” with about a third of the depth soldered to the column with the remaining 2/3 as a socket for the top half.
The one photo shows a view into the collection reservoir, I am showing it as I was able to do a slight single flare bulge to the end on the tube that sure cleans up the transition.
Well, I've come to understand that there is a possibility that this particular design has not been tried? So, I guess we will see,...................... I will keep you posted. Cheers O'Mahony
Additional photos:
http://i270.photobucket.com/albums/jj85 ... ny/138.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i270.photobucket.com/albums/jj85 ... ny/141.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i270.photobucket.com/albums/jj85 ... ny/149.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i270.photobucket.com/albums/jj85 ... ny/137.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i270.photobucket.com/albums/jj85 ... ny/151.jpg" onclick="window.open(this.href);return false;" rel="nofollow
http://i270.photobucket.com/albums/jj85 ... ny/133.jpg" onclick="window.open(this.href);return false;" rel="nofollow
